okay, please open a terminal, go to the tmm folder and launch the shellscript (tinyMediaManager.sh) - with version 2.6
maybe there is some output to the console which does not land in the logs
Hello again. Well, I just kept using Java 1.6, but with today's update came a warning that this version will be unsupported. So I tried other Java versions... And *again* there was the problem of blank gray, screens.
I finally found how to solve this. Also see:
https://awesome.naquadah.org/wiki/Problems_with_Java
It is really stupid, but apparently, the "problem" was that I am using xmonad. I'm not familiar with any of this, so I won't try to seem smart
Just see this quote from the page:
Quote:Impersonate Another Window Manager
You may use the wmname utility to make the JVM believe you are running a different window manager. This utility is available in the suckless-tools package in Debian (and Ubuntu); this Portage tree provides wmname for Funtoo (and Gentoo).
(You must restart the application in question after issuing the wmname command.)
This works because the JVM contains a hard-coded list of known non-re-parenting window managers. For maximum irony, many users prefer to impersonate “LG3D,” the non-re-parenting window manager written by Sun, in Java.
So... first I do 'wmname LG3D' and then start up TMM. And voila. It works.
This is probably the most annoying and strange problem I have ever come across. But I wanted you to know about this, for if others get the same issues as I have had for many months.
