Full Version: Trying to compare numbers to show specific text
Hello everyone. I'm trying to show the number of unwatched episodes if there are any, and if there aren't any then I want to show nothing.
I'm not sure if I'm doing it right though. Well obviously I'm not or I wouldn't be here.
I have a variable in one xml liek this:
<variable name="ShowUnwatched">
    <value condition="gt(ListItem.Property(UnWatchedEpisodes),0)">$INFO[ListItem.Property(UnWatchedEpisodes)] $LOCALIZE[16101]</value>
    <value></value>
</variable>
And then I'm using that variable for a label like so:
<label>$VAR[ShowUnwatched]</label>
It only shows the blank though and never the number of unwatched episodes. Is this an incorrect way of using the compare functions?
Ok, I tried using StringCompare instead with this:
    <value condition="!StringCompare(ListItem.Property(UnWatchedEpisodes),0)">$INFO[ListItem.Property(UnWatchedEpisodes)] $LOCALIZE[16101]</value>
    <value></value>
</variable>
And that worked so I guess that means the returned value from Property(UnWatchedEpisodes) is a string and not a number... weird... except that the top item that says "up one level" also now has the "unwatched" text which I of course don't want. Any idea how to fix that?
