2014-07-17, 12:54
2014-07-17, 12:54
2014-07-17, 15:32
Did some more digging -
So the question is: Is this still not possible without a big overhead?
(2011-03-30, 18:58)Hitcher Wrote: [ -> ]According to the wiki -
Quote:Shows a concatenated string of cast members of the currently selected movie in a list or thumb control
But I can't get it to show anything in a list.
Bug?
(2011-03-30, 19:27)spiff Wrote: [ -> ]not a bug. problem is it requires many extra queries which slows down the listing tons...
(2011-03-30, 19:52)spiff Wrote: [ -> ]no, it's available in the info dialog... eventually we'll add background fetching of info, then it will be avail in the listings as well (after a brief delay).
2014-07-19, 00:00
Paging Johnathan.
2014-07-19, 04:15
Short answer: yes. If you examine the JSON-RPC requests being made, you'll see a separate query (or 3) done for each item.
I think some cleanup work on the background loader would be needed before this was efficient.
2014-07-19, 08:13
OK, thanks for the reply. Looks like we need to change the label.
