Full Version: Android mini pc stick to run XBMC
Can anyone recommend one that works with XBMC and has full hardware acceleration??Are there any??
Would something like this work??
http://www.amazon.com/CX-919-RK3188-Blue...B00CRTCTVA
Its has a RK3188 processor.
http://www.rock-chips.com/a/en/products/...8/314.html
Process    • 28nm low power process
CPU    • Quad-core ARM Cortex-A9, up to 1.6GHz
GPU    • Mali-400MP4 GPU, up to 600MHz
Graphic Computing    • Support OPENGL ES1.1/2.0, OPEN VG1.1
• High performance dedicated 2D processor
• 1080P multi format video decoding (H.265 and VP9)
• 1080P video encoding for H.264 and VP8
Display    • Dual-panel display and perfect for 2048x1536 resolution
Camera    • Support dual camera
Flash     • Support MLC NAND, eMMC
Memory    • Full memory support, DDR3, DDR3L, LPDDR2
Connectivity    • Rich peripheral and connectivity
The guys at FreakTab forums would better answer which Chinese stick is better. You want one that has good support. If the firmware is crap, could end up with sync issues that never get fixed, or lack of updates. I would go with a AmLogic chip, better supported. More open than Rockchip, unless something has changed lately.
It's pretty good hardware, but expect wifi to suck. Either plan on low-bitrate streams, local files on the microSD card or USB, some better wifi via USB, or ethernet via USB. Also, I find flashing the firmware of rockchips devices to be a PITA, but the hardware itself is very good bang for your buck.
