Full Version: settings.xml put on userdata folder more better
settings.xml put on userdata folder more better than e:\udata\0face008 .
i think userdata folder is all user data for xbmc user , so settings.xml is also ,
if this , i can use diff xbmc version , because some new cvs version is not stable.
i suggest put to userdata\setting folder or userdata\config\
it's been the plan all along... :agree:
wait you do it!
xboxmediacenter.xml also suggest to userdata folder , and change name to bookmark.xml
