this is a simple addon to play music videos via youtube.
Supported sources:
- Beatport
- Billboard
- iTunes Charts
- Official Charts Company (UK)
- Spotify Playlists
Autoplay modes are available via context menu (Autoplay All/Top10/.../Top50).
Per default, a notification appears 5 seconds after video playback has begun (autoplay mode).
It's available via my
testing-repo...
EDIT: fixed version in this post:
http://forum.kodi.tv/showthread.php?tid=...pid2096728
Would be awesome if we just could browse Spotify the normal way like we can on our desktop/mobile with free accounts.
Now we can only select playlists.
Don't understand why it isn't possible with free accounts.
Still a great addon
Interesting i will try.
Peppe
EDIT
super cool addon.
thanks a lot.
Peppe
v1.0.1:
- Changed default folder icon
(2014-07-24, 21:03)schumi2004 Wrote: [ -> ]Would be awesome if we just could browse Spotify the normal way like we can on our desktop/mobile with free accounts.
There are already some normal Spotify addons available where you can browse/play your music as you would do with the Spotify app.
This addon was not planned - it's just a spin-off from the much more advanced
My Music TV addon. It worked so well, so I thought I just publish a small separate addon.
Maybe I'll improve this addon in the future and add login and so on...
(2014-07-24, 21:03)schumi2004 Wrote: [ -> ]Now we can only select playlists.
That's what my description says: "this is a simple addon to browse and play popular Spotify playlists via XBMC"
(2014-07-24, 21:03)schumi2004 Wrote: [ -> ]Don't understand why it isn't possible with free accounts.
Sure, it's possible. It just needs to get implemented.
Edit: To avoid confusion: A premium account is NOT required. You don't need an account at all...
This is working well so far - great way to watch some different music videos sorted by genre (e.g. playlists).
Had to create an account on here. Long time reader, first time poster. This is a fantastic addon, been using it flatout for a few days and works perfectly. Im also a spotify subscriber this complements it fantastically. Thanks for all the work on this.
(2014-07-27, 16:31)AddonScriptorDE Wrote: [ -> ]v1.0.1:
This addon was not planned - it's just a spin-off from the much more advanced My Music TV addon. It worked so well, so I thought I just publish a small separate addon.
Thanks for all your hard work, i couldn't find a addon though that didn't required a premium account that allows me to browse and search spotify yet
(2014-07-28, 21:36)schumi2004 Wrote: [ -> ]Thanks for all your hard work, i couldn't find a addon though that didn't required a premium account that allows me to browse and search spotify yet
Neither do i, we need a hint
Peppe
hi great addon is it possible to add a search button ? thx
(2014-07-29, 14:36)Zombi Wrote: [ -> ]hi great addon is it possible to add a search button ? thx
I dont think this actually uses spotify as such. It just reads the spotify playlists and then serves them up via youtube. So essentially its just a youtube search you would be doing which you can already do with the youtube addon.
Only issue found is that when a item doesn't exist on Youtube it stops playing playlist and you need to start it again.
Maybe this can be fetched to skip track and start next?
(2014-07-29, 15:51)danjericho Wrote: [ -> ] (2014-07-29, 14:36)Zombi Wrote: [ -> ]hi great addon is it possible to add a search button ? thx
it is not the same for me it would be nice if I can search for a specific spotify playlist other than available under genre or toplists etc
v1.0.2:
- Changed name from "SpotiTube" to "Youtube Music"
- Removed info when not using Autoplay mode
- Added support for Billboard Charts
- Added support for iTunes Charts
I removed the browse/autoplay branch. Use the context menu for autoplay...
(2014-07-29, 17:58)schumi2004 Wrote: [ -> ]Only issue found is that when a item doesn't exist on Youtube it stops playing playlist and you need to start it again.
Could not reproduce this. A normal playlist is created and the addon has no control over playback.
For me, non working vids are just skipped...
