My xbmc just starting doing this the other day (or I just noticed it), as soon as a video finishes playing, it'll just replay itself. Is there a setting I accidentally changed? I looked through the options, but I couldn't find anything.
I'm on Gotham btw.
(2014-07-22, 03:20)m0ngr31 Wrote: [ -> ]My xbmc just starting doing this the other day (or I just noticed it), as soon as a video finishes playing, it'll just replay itself. Is there a setting I accidentally changed? I looked through the options, but I couldn't find anything.
I'm on Gotham btw.
While xbmc is not running open guisettings.xml change video repeat to false.
I think that worked. Thanks!
The GUI setting is kind of hidden in the default skin (Confluence) and various other skins. It can also be turned on from an add-on or a remote app. In the GUI it should be with the "Current playlist" controls, where you queue up a video to play, then open the lefthand sidebar menu and select "current playlist", then open op the lefthand sidebar menu again.
