Hi there,
I was wondering if there is a possibility to define different audio outputs for Music Files and Movies.
The Background being, that I use different Hi-Fi Systems for my Home Cinema and my Music System in the Living room.
The Sound for the Home Cinema should be handled via HDMI.The Sound to the Stereo Systems goes through a USB DAC.
THX for your help
Ciao Nephylim!
There is no way to have such feature as it is in the XBMC official release (please take a look to this post that I initiated some times ago
http://forum.xbmc.org/showthread.php?tid=197409...maybe you have some nostalgia of MediaPortal?).
Anyway two way forward for this issue:
- Dual Audio patch (
http://forum.xbmc.org/showthread.php?tid=192480): this activates two different output devices at the same time;
- Audio Switch (
http://forum.xbmc.org/showthread.php?tid=199579): it provides a script (that you can run for example when opening a specific menu in the home page) to configure the audio device (and related parameters) you would like to use.
Personally I use the second one that to me seems a more clean way to proceed!
Buona giornata,
Alex (from HTPC Italia)
Maybe i can help you out in a few days...
I wrote a Service Addon which automatically switches audio output when playing Music or Movies. The setup can be done within xbmc, so no fiddling with log files or code manipulation is required.
it works so far but i am still testing and try to optimize the code (i am a beginner in coding python...).
Due to work and family i haven't got much time, but i think i can release it soon, at least for testing purposes.
cya
(2014-07-24, 16:09)marv_el Wrote: [ -> ]Maybe i can help you out in a few days...
cya
Please consider me in the list for testing!
Thanks in advance for your work!
ok, download the zip from here and install it:
https://www.dropbox.com/s/pwc2bfz7konilx...switch.zip
1) go to the addon settings and enable "run audio device settings" - click OK.
2) configure your desired audio setting in the xbmc settings
3) play a music file (you will be notified that the device was saved)
4) do the same point 2) and 3) for videos
5) that's it. from now on the service addon should switch devices automatically.
additionally you can go to the addon settings and change passthrough and the amount of channels.
you even can chose the audio output for the gui.
please be aware that it is an early version. feel free to test it.
Hi marv_el!
I have just saw your post...I will make some trials and let you know!
Cheers!
Here I Am!
So, I have tested it on my notebook and it seems to work great!
Just to let you know: for movies I have configured the speakers while for music the speakers with WASAPI and...it works!
One question: in case I would like to uninstall the add-on, how the audio configuration will be restored? In other words, which audio device will be used for both video and music?
Lets syncro!
glad, its working...
if you deactivate the addon, the last audio setting will be used. after activating the addon again, it should work as expected.
in case you uninstall the addon you have to do the setup again after re-install it. i have saved the configuration files within the addon instead of the addon_data directory. i will change that in the next release, so the audio config files won't be deleted, even if you uninstall the addon (afaik).
i will add a "swap device" script, which can be bound to a key. so you can change the audio output manually as well. i need this for myself, in case i want to watch MUSICVIDEOS using the "MUSIC" device instead of the VIDEO device.
so long
Many thanks for your work!
What is "sad" is that it seems that there is no much interest on this topic from the community...having said this, please let me know if I have to do something to support you for an embedded and official feature of XBMC!
As a first step to gain more visibility, I would suggest to open an ad-hoc topic in the XBMC development section...what do you think?
i will open a thread as soon as i am ready for an official release - maybe this weekend!
i appreciate your support, thanks!
axlt2002:
i have added a possibility to switch the audio device manually.
could you please try it out?!
please uninstall(!) the previous version, because i made changes regarding the location of the audio configs. you need to run the setup again after installing the new version from here:
https://www.dropbox.com/s/17906u0bq5ekyv....0.1.0.zip
please bind a key to
XBMC.RunScript(special://home/addons/script.audioswitch/manualswitch.py to switch manually as well.
which OS do you use btw.?
thanks for helping out!
Hi marv_el!
Nice to hear you! ;-) Sorry but I was out for a small-long weekend and now waiting for the long vacations!
So, I've just seen that you made some good progress...I will try to test it as soon as possible as usual and let you know!
So...stay tuned!
Btw, the machine on which I have tired your addon is running Windows 7. At home I hacve a couple with 8.1, but actually I have not so much time to try it also there...
Honoured to help you!
Hello,
Thank you for your works, I wait for this since a long long time...
So thank you very much.
I will try this ASAP.
Have you release your works ?
