2014-08-23, 12:39
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
2014-08-23, 12:45
You are correct. Must have recently changed. I will look into it
2014-08-23, 13:33
(2014-08-23, 12:20)takoi Wrote: [ -> ](2014-08-23, 09:21)adb76 Wrote: [ -> ]One question: have you planned to implement also "Favorite Playlists" - that would be great!Afaik, when you star a playlist it will be added to 'my playlist'. There is no 'favorite playlists'
Your add-on currently only shows the playlists I've created manually in Wimp. Playlists which I marked as favourites are not shown. In the wimp application under Windows they are also separated: My own playlists are in the category "My playlists" and the marked playlists in the category "My Favourites --> My Playlists".
But you are right: In the web player they are all in the category "My Music --> Playlists". Strange...
So I suspect that wimp "internal" these are different playlist types - that's perhaps why your add-on only shows the one type.
2014-08-23, 13:58
Already fixed;). Get development snapshot from github
2014-08-24, 13:24
Great work!
This will be really nice if/when they add HiFi support to the webplayer.
2014-08-24, 14:13
I may be stupid, but if I use the link from page one I get the old version.
Are I'm doing something wrong?
2014-08-24, 14:56
(2014-08-24, 14:13)larskb Wrote: [ -> ]I may be stupid, but if I use the link from page one I get the old version.
Go to the github page and click on download zip.
2014-08-24, 16:10
2014-08-24, 17:55
(2014-08-23, 13:58)takoi Wrote: [ -> ]Already fixed. Get development snapshot from github
Thank you! It works great!
2014-08-31, 08:44
I tried to install the Wimp addon now through the repository. The version directly from github does work but not the Version 1.0.0 from the repository. For me it seems that there are files missing in the zip file ( the whole wimpy sub directory):
OpenELEC:~/.xbmc/addons/packages # unzip -l plugin.audio.wimp-1.0.0.zip
Archive: plugin.audio.wimp-1.0.0.zip
98e7dc3480c9db9ab62acab2844d02968595b1eb
Length Date Time Name
0 08-30-2014 08:09 plugin.audio.wimp/
35148 08-30-2014 08:09 plugin.audio.wimp/LICENSE.txt
7461 08-30-2014 08:09 plugin.audio.wimp/addon.py
1064 08-30-2014 08:09 plugin.audio.wimp/addon.xml
0 08-30-2014 08:09 plugin.audio.wimp/changelog.txt
99045 08-30-2014 08:09 plugin.audio.wimp/fanart.jpg
17750 08-30-2014 08:09 plugin.audio.wimp/icon.png
3929 08-30-2014 08:09 plugin.audio.wimp/routing.py
164397 8 files
2014-08-31, 18:54
Something went wrong during pull. There should be an update out for it now.
2014-09-16, 20:43
Seems like there is a bug when starting a song, tried on three different albums. It starts on one track higher than the selected, ex 1st becomes 2nd, 2nd plays 3rd etc. Have to skip backwards to play the first song.
Could this be a simple error with something starting at 0 instead of 1.
Edit:
A few more observations: If i skipped back to the first track, it would play the 3rd track next. It also skipped to the 4th song after completing the 2nd. Then to the 5th and so skipped to the 7th. Something is a bit wonky with song order.
On one attempt it did play the first track when i selected that, that happened after one or two songs from that album had completed, i stopped and selected the first track again.
These few attempts have been done in favorite artists and selecting songs from the albums.
Also the Last.fm scrobbler doesn't scrobble songs played with this add-on. Not sure thats an issue with this add-on or not, or if its something that is fixable. Just thought i mention it i case it is
Edit:
2014-09-21, 12:15
(2014-09-16, 20:43)Crowly Wrote: [ -> ]Seems like there is a bug when starting a song, tried on three different albums. It starts on one track higher than the selected, ex 1st becomes 2nd, 2nd plays 3rd etc. Have to skip backwards to play the first song.It's playback failing so xbmc automatically goes to the next on the list. I've been noticing it too. It started recently. Sometimes it plays just fine on first attempt, sometimes on second. And some tracks won't play at all.
2014-10-09, 14:37
Nice work!
Can you PLEASE fix support for HiFi (lossless)?
That would be absolutely perfect. If you send me your paypal ID, I can sponsor you with a month of free wimp hifi if you need that.
2014-10-09, 14:49
Wimp web player beta lab:
https://plus.google.com/u/0/communities/...6192854829
if you become a beta tester here, you get access to the next-gen wimp web player with hifi support
