Since today i cant login into Tidal.
So i made an update to the new version, but same problem.
Then i updated to Kodi 19 and used the other version of the new repository, but also same problem.
I activated logging and there are some errors.
deleted the unique key from this log, dont know if it is necessary.
Line 40: 2021-04-14 10:39:32.383 T:10668 INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: context.item.tidal2 v0.2.0 installed
Line 78: 2021-04-14 10:39:32.387 T:10668 INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: plugin.audio.tidal2 v2.0.1 installed
Line 83: 2021-04-14 10:39:32.388 T:10668 INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: repository.tidal2 v0.2.0 installed
Line 924: 2021-04-14 10:47:52.777 T:5004 INFO <general>: CPythonInvoker(55, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 927: 2021-04-14 10:47:55.960 T:4700 ERROR <general>: [TIDAL2] Client not found
Line 928: 2021-04-14 10:47:56.017 T:4700 ERROR <general>: [TIDAL2] Forbidden
Line 931: 2021-04-14 10:47:57.340 T:4700 ERROR <general>: [TIDAL2] Client not found
Line 935: 2021-04-14 10:48:00.000 T:4700 ERROR <general>: [TIDAL2] Client not found
Line 939: 2021-04-14 10:48:02.295 T:4700 ERROR <general>: [TIDAL2] Client not found
Line 940: 2021-04-14 10:48:02.297 T:4700 INFO <general>: CPythonInvoker(56, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 943: 2021-04-14 10:48:02.836 T:2208 INFO <general>: CPythonInvoker(57, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 946: 2021-04-14 10:48:05.943 T:2184 INFO <general>: CPythonInvoker(58, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 974: 2021-04-14 10:48:41.797 T:2440 INFO <general>: CPythonInvoker(59, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 980: 2021-04-14 10:48:47.367 T:7476 INFO <general>: CPythonInvoker(61, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 983: 2021-04-14 10:48:52.253 T:9364 INFO <general>: [TIDAL2] Try Login with amarra Token wc8j_yBJd20zOmx0 ...
Line 984: 2021-04-14 10:48:52.253 T:9364 INFO <general>: [TIDAL2] Using Token "wc8j_yBJd20zOmx0" with clientUniqueKey "xxxxxxxx"
Line 985: 2021-04-14 10:48:53.597 T:9364 ERROR <general>: [TIDAL2] Client not found
Line 986: 2021-04-14 10:48:53.597 T:9364 INFO <general>: [TIDAL2] Try Login with ios Token _DSTon1kC8pABnTw ...
Line 987: 2021-04-14 10:48:53.597 T:9364 INFO <general>: [TIDAL2] Using Token "_DSTon1kC8pABnTw" with clientUniqueKey "xxxxxxxx"
Line 988: 2021-04-14 10:48:54.922 T:9364 ERROR <general>: [TIDAL2] Client not found
Line 989: 2021-04-14 10:48:54.922 T:9364 INFO <general>: [TIDAL2] Try Login with native Token 4zx46pyr9o8qZNRw ...
Line 990: 2021-04-14 10:48:54.922 T:9364 INFO <general>: [TIDAL2] Using Token "4zx46pyr9o8qZNRw" with clientUniqueKey "xxxxxxxx"
Line 991: 2021-04-14 10:48:54.981 T:9364 ERROR <general>: [TIDAL2] Forbidden
Line 992: 2021-04-14 10:48:54.981 T:9364 INFO <general>: [TIDAL2] Try Login with tizen Token M6ztoSvmny6alVCD ...
Line 993: 2021-04-14 10:48:54.981 T:9364 INFO <general>: [TIDAL2] Using Token "M6ztoSvmny6alVCD" with clientUniqueKey "xxxxxxxxx"
Line 994: 2021-04-14 10:48:56.145 T:9364 ERROR <general>: [TIDAL2] Client not found
Line 995: 2021-04-14 10:48:56.145 T:9364 INFO <general>: [TIDAL2] Try Login with vizio Token Y40WSvVnnG0ql0L0 ...
Line 996: 2021-04-14 10:48:56.145 T:9364 INFO <general>: [TIDAL2] Using Token "Y40WSvVnnG0ql0L0" with clientUniqueKey "xxxxxxxxx"
Line 997: 2021-04-14 10:48:57.299 T:9364 ERROR <general>: [TIDAL2] Client not found
Line 998: 2021-04-14 10:48:57.299 T:9364 INFO <general>: [TIDAL2] Try Login with tv Token NIh99tUmaAyLNmEA ...
Line 999: 2021-04-14 10:48:57.300 T:9364 INFO <general>: [TIDAL2] Using Token "NIh99tUmaAyLNmEA" with clientUniqueKey "xxxxxxxx"
Line 1000: 2021-04-14 10:48:58.649 T:9364 ERROR <general>: [TIDAL2] Client not found
Line 1001: 2021-04-14 10:48:58.649 T:9364 INFO <general>: [TIDAL2] Try Login with ios2 Token hZ9wuySZCmpLLiui ...
Line 1002: 2021-04-14 10:48:58.649 T:9364 INFO <general>: [TIDAL2] Using Token "hZ9wuySZCmpLLiui" with clientUniqueKey "xxxxxxxxx"
Line 1003: 2021-04-14 10:48:59.982 T:9364 ERROR <general>: [TIDAL2] Client not found
Line 1004: 2021-04-14 10:48:59.984 T:9364 INFO <general>: CPythonInvoker(62, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 1007: 2021-04-14 10:49:00.574 T:1936 INFO <general>: CPythonInvoker(63, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\addon.py): script successfully run
Line 1131: 2021-04-14 10:49:36.859 T:8924 INFO <general>: CPythonInvoker(4, C:\Users\vdr\AppData\Roaming\Kodi\addons\plugin.audio.tidal2\service.py): script successfully run
Perhabs someone can help me
