Full Version: Remote not working
HI Guys,
Recently I upgraded my XBMC h/w to a nifty ZOTAC ZBOX Sphere OI520, so I thought... The problem is I can't get my MCE remote to work (harmony 600 with MCE IR Receiver).
It worked perfectly fine on my other system(s) for years, but with the new h/w config in Gotham the remote does not work at all.
The receiver light blinks whenever I press a key on the remote, but nothing happens in the interface. Reinstalled my old Frodo config: same problem, no remote! USB keyboard works fine though.
Funny thing is when I install OpenELEC the remote works fine - out of the box. WTF?!
So, I thought, what if I reinstall Gotham with the remote receiver connected during install? No luck either. I don't want to go back to OpenELEC Sad
Any clues? Tried every USB port and option within Gotham. Please help.
Update: Tried the LIRC command 'irw' to check if any key is pressed. No luck either. Strange.
