Hi. I am using XBMC Gotham Beta. 13.2 beta.
I have installed Cinema Experience and set everything up. But when I go to play a movie I simply can't find how to play it with cinema experience. I am new to CE but been using XBMC for a while. Am i doing something wrong
What skin are you using ?
For me on MQ5 I find the movie I want to watch, view it's movie info and there is an option for Cinema Experience.
(2014-07-27, 06:12)Ic3y Wrote: [ -> ]What skin are you using ?
Hi, am usinng Aeon MQ5, but i cant find the option too start CE. I press enter and the movie starts, unless im missing a trick.
Highlight the movie you want to play, but open the context menu instead of pressing enter. Click on 'movie information'. The cinema ex button is the fourth from the left.
There is also the option in cinema ex's settings under miscellaneous to override the play button to always start cinema ex. It works for me, but there is a note to say its experimental and may not work.
(2014-07-27, 11:58)black_eagle Wrote: [ -> ]Highlight the movie you want to play, but open the context menu instead of pressing enter. Click on 'movie information'. The cinema ex button is the fourth from the left.
Hi.
Under Context menu there is no option for movie information.
(2014-07-27, 12:49)Manfonse Wrote: [ -> ] (2014-07-27, 11:58)black_eagle Wrote: [ -> ]Highlight the movie you want to play, but open the context menu instead of pressing enter. Click on 'movie information'. The cinema ex button is the fourth from the left.
Hi.
Hi, i reinstalled everything, its now wroking.
Thanks for the help.
