Full Version: YouTube (IMPORTANT - READ FIRST POST)
(2015-10-01, 04:22)blueribb Wrote: [ -> ]https://superrepo.org/kodi/addon/plugin.video.youtube/
Click on "Download" and then "Download from official mirror"
In Kodi, go to System / Add-ons / Install from ZIP file and navigate to the zip file you downloaded
No superre** links please!
See banned_add-ons (wiki)
I'm using YouTube add-on 5.19 and Kodi 15.1 and i'm receiving the following message when trying to sign in on the YouTube app.
"Please log in twice......"
I click ok and the next screen comes up saying "Go to 'youtube.com/activate'".
I can do this via phone or external browser, however the YouTube app doesn't bring up any code that that I need to enter on the above URL. Eventually it gets to 100% and says "YouTube error. Check the log for more information".
Could you please advise what I need to do here to fix this? Thank you.
(2015-10-01, 12:46)Runestrider Wrote: [ -> ]Hi,
You've to press okay again to see the first code in KODI.
Still no subtitles?
(2015-10-01, 16:40)zeon_xp Wrote: [ -> ]Still no subtitles?
No...the minimum of 200 quota points per request is not cheap and will result in an possible early shutdown of the addon everyday.
Hi, I've updated Kodi to 15, and plugin work like a charm. Thanks for help.
It would be great if advanced users could sign up for their own API key and use that somehow. Lots of twitter apps did that when they started restricting users.
(2015-10-01, 16:13)bromix Wrote: [ -> ]
Thanks for the reply. There is no option to push ok again sorry. It just stays on Sign In - XX% counting up, with a cancel option.
(2015-10-02, 00:00)Runestrider Wrote: [ -> ]
Do you see the code in the dialog? If not, what skin you're using?
(2015-10-02, 09:26)bromix Wrote: [ -> ]
(2015-10-01, 16:13)bromix Wrote: [ -> ]You've to press okay again to see the first code in KODI.
I changed the skin, that worked! Thank you very much. I was using "Neon" skin. I hope you have a good day.
I use UBUNTU & Kodi 15 15.1 Git:d496682 Media Center Kodi
Teme Confluence
Youtube addon I updated to version 5.1.9
See error pleas http://paste.ubuntu.com/12637984/
I tried to sign in
All dependent addons also stopped working
CPythonInvoker(25, /home/xbmc/.kodi/addons/plugin.video.youtube/default.py): script didn't stop in 5 seconds - let's kill it
Run now
DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
15:55:38 T:139896068990720 NOTICE: [plugin.video.youtube] Running: YouTube (5.1.9) on Isengard (15.1) with Python 2.7.6
15:55:38 T:139896068990720 DEBUG: [plugin.video.youtube] Path: "/special/disliked_videos/
15:55:38 T:139896068990720 DEBUG: [plugin.video.youtube] Params: "{}"
15:55:38 T:139896068990720 DEBUG: [plugin.video.youtube] Selecting YouTube config "Isengard"
15:55:38 T:139896068990720 DEBUG: [plugin.video.youtube] User is logged in
Browse history 5 min. And open
I pres back and select my channels
Browse a very long time
15:58:34 T:139896068990720 NOTICE: [plugin.video.youtube] Running: YouTube (5.1.9) on Isengard (15.1) with Python 2.7.6
15:58:34 T:139896068990720 DEBUG: [plugin.video.youtube] Path: "/channel/mine/
15:58:34 T:139896068990720 DEBUG: [plugin.video.youtube] Params: "{}"
15:58:34 T:139896068990720 DEBUG: [plugin.video.youtube] Setting content-type: "episodes" for "/channel/mine/"
15:58:34 T:139896068990720 DEBUG: [plugin.video.youtube] Selecting YouTube config "Isengard"
15:58:34 T:139896068990720 DEBUG: [plugin.video.youtube] User is logged in
15:58:34 T:139896068990720 DEBUG: [plugin.video.youtube] No data for channel 'mine' cached
15:58:34 T:139896068990720 DEBUG: POParser: loaded 100 strings from file /home/xbmc/.kodi/addons/plugin.video.youtube/resources/
15:58:34 T:139896068990720 DEBUG: POParser: loaded 0 strings from file /home/xbmc/.kodi/addons/plugin.video.youtube/resources/la
I open Users browsing
16:01:11 T:139896094168832 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
16:01:11 T:139896094168832 NOTICE: [plugin.video.youtube] Running: YouTube (5.1.9) on Isengard (15.1) with Python 2.7.6
16:01:11 T:139896094168832 DEBUG: [plugin.video.youtube] Path: "/special/popular_right_now/
16:01:11 T:139896094168832 DEBUG: [plugin.video.youtube] Params: "{}"
16:01:11 T:139896094168832 DEBUG: [plugin.video.youtube] Selecting YouTube config "Isengard"
16:01:11 T:139896094168832 DEBUG: [plugin.video.youtube] User is logged in
16:01:11 T:139896094168832 DEBUG: [plugin.video.youtube] Setting content-type: "episodes" for "/special/popular_right_now/"
16:01:11 T:139899092907968 DEBUG: ------ Window Init (DialogBusy.xml) ------
16:03:19 T:139896094168832 DEBUG: [plugin.video.youtube] No data for video '5m-pNC76mCc' cached
16:03:19 T:139896094168832 DEBUG: [plugin.video.youtube] No data for video 'SUaNZicTcrM' cached
16:05:26 T:139896094168832 DEBUG: [plugin.video.youtube] No data for channel 'UCiEm_OC7Z2EsuMwFXp6cODg' cached
16:07:34 T:139896094168832 DEBUG: [plugin.video.youtube] Converting VideoItem
16:07:34 T:139896094168832 DEBUG: Previous line repeats 29 times.
I run play first opened entry
16:08:59 T:139896102561536 DEBUG: [plugin.video.youtube] User is logged in
16:09:00 T:139899092907968 DEBUG: DialogProgress::StartModal called
16:09:00 T:139899092907968 DEBUG: ------ Window Init (DialogProgress.xml) ------
16:11:07 Video opened - very very slow Sad
Hey, As a skinner, what is my option to use you addon? I saw:
ActivateWindow(videos,plugin://plugin.video.youtube/kodion/search/query/?q=QUERY)
and
ActivateWindow(videos,plugin://plugin.video.youtube/kodion/search/query/?q=QUERY&search_type=playlist)
What else can be used?
I need the options to search by channelid\userid, and by duration (if possible, to define to return videos only if longer then X minutes)
(2015-10-02, 15:56)tomer953 Wrote: [ -> ]Hey, As a skinner, what is my option to use you addon? I saw:
and
There are end points defined in the first post of this thread. Please keep in mind that searches deplete the quota of the API of the addon. So please make use of useful and poll optimized searches.
(2015-10-02, 14:21)sovaby Wrote: [ -> ]I use UBUNTU & Kodi 15 15.1 Git:d496682 Media Center Kodi
Teme Confluence
I tried to sign in
Run now
Please full debug logs via pastebin.com or similar services.
(2015-10-02, 16:30)bromix Wrote: [ -> ]
and
Thanks for the quick reply.
I saw the links, great!
Still, no option by using you addon to filter videos by duration? I need to search by title+duration, only titles is not working for what i'm trying to achive
