Full Version: YouTube (IMPORTANT - READ FIRST POST)
Now that we got that out of the way... can anyone help with my issue?
kodi youtube addon missing activation codes on initial login. Last night I did a factory reset throough clockwork mod of my FireTV. Fresh install, Kodi is new, shiny & bright!
Upon initial setup of youtube I start the activation wizard, choose thumbnails etc. etc. it the tells me I need to enable two applications so that youtube is functioning properly. after clicking OK, I just get a "login failed" message instead of the activation codes.
I've gone through this process a few times in the past. I know what I'm looking for, it's just not showing up.
What am I missing?
Here's my log if it helps at all: http://pastebin.com/raw.php?i=zRjw7xkh
(2015-12-08, 05:43)fiddystorms Wrote: [ -> ]Now that we got that out of the way... can anyone help with my issue?
What am I missing?
Sorry, based on you log you're using at least 2 banned addons. Some of the addons cause warnings and a lot of errors. Sort them first out, better remove them completely.
(2015-12-07, 04:45)NeoCortex Wrote: [ -> ]
(2015-12-07, 03:25)DjDiabolik Wrote: [ -> ]...
Are you running the Jarvis beta? It's a known issue there and likely due to changes in Jarvis. Sorting should be working fine in Isengard.
Should be already fixed in 5.1.12
(2015-12-06, 14:50)htpcnas Wrote: [ -> ]Hi guys,
I've got xbmc isengard installed on my pc. I have also the latest youtube add-on v5.x.x. Now here's the issue....When I play youtube videos from my playlist, most videos play fine, but a small minority are simply not playing. But if I try this directly on youtube.com via pc browser, the videos play fine.
I've tried to uninstall/reinstall, but have had no luck and I'm beginning to wonder if the plugin has a bug?
I've uploaded the xbmclog file HERE and would be most grateful if you could help me with this issue.
Sorry, nothing the log based on the addon. Provide a log using the addon.
(2015-12-06, 10:03)jdf76 Wrote: [ -> ]hey bromix
i know you aren't fond of this idea, but would it be possible for me to use my own API Key in the script, would i have to do anything special like recompile.
I understand i take my own responsibility if I break the add-on and you wouldn't help me with it.
Thanks for any info you give i appreciate it.
Jeff
I've another idea...but I've so little time at the moment and don't want to complicate things with the addon Wink in Python you do not really recompile Wink
(2015-12-03, 17:37)Cal777 Wrote: [ -> ]
(2015-12-03, 16:26)Cal777 Wrote: [ -> ]
(2015-12-03, 09:38)bromix Wrote: [ -> ]Sort is working fine for me with 15.2 and 16.X...be more specific.
5.1.11 version used to have a sort option that was "Year" now it is "Date" with the 12 version. On both my windows 7 machine running 15.2 with Aeon Nox Skin, and RP2 running 14.2 with confluence skin, they will not sort the search by "Date" properly. The videos are not organizing by the dates for ascending or descending. Before the automatic update to 12, a few days ago, it was working fine. I would do a rollback, to see if 12 is the problem, but that option is greyed out.
watch gallery
I attached (2) supporting images. One with the search settings and another with the results. Notice that the videos are not arranged in a date specific order. They should be arranged chronologically as the setting would suggest. Again, this worked perfectly in version 11.
[/quote]
Bromix: Any ideas on why the "sort by" for date does not work?
Does the addon going to support 1080P playback ??
(2015-12-08, 21:51)macavita Wrote: [ -> ]Does the addon going to support 1080P playback ??
http://forum.kodi.tv/showthread.php?tid=202203
After many years at a standstill there's actually some hope on this now, with development being done, as ffmpeg now supports DASH. Exciting stuff!!
http://forum.kodi.tv/showthread.php?tid=...pid2148409
Note: Please don't post questions in the development forum unless you're a coder, they prefer to keep enduser discussion separate.
Anyone else have an issue where audio doesn't start playing until a second or two after unpausing? Just upgraded to Isengard and the issue appeared at that time.
Hi, does this add-on supports youtube 'restricted mode'?
If YES - is there any way to switch between 'restricted mode' OFF/ON.
If NO - is there any chance to add such support?
I think some parents will be thankful.
Regards
Hi
I have the same issue as others about the "dalily limit exceeded" but something weird is that on Helix 14.2 (macbook pro) youtube works great but on Isengard 15.2 (Openelec 6 and macbook pro) the problem occurs.
My youtube is 5.1.12 from your github page
Same thing with the Popular right now section, on 14.2 it's all right but on 15.2 it tells me Unknown kind "
I don't know why but i hope you find the solution.
Thanks for the work!
A new error message just started for me on 2 different devices. When I click on "Subscriptions" an error box appears that says "Exception in Content Provider" and under that it says "unknown kind". In the "My Subscriptions" folder, all the videos from all my subscriptions are listed but without thumbnails and they do play.
Intel NUC w/ OpenELEC 6.0.0
Windows 10 desktop running Kodi 15/2
@faresqc: The addon uses different API keys for each kodi version. That's why you need to re-authenticate after upgrading.
(2015-12-13, 05:24)blueribb Wrote: [ -> ]A new error message just started for me on 2 different devices. When I click on "Subscriptions" an error box appears that says "Exception in Content Provider" and under that it says "unknown kind". In the "My Subscriptions" folder, all the videos from all my subscriptions are listed but without thumbnails and they do play.
I have this same issue though I am running windows 10 1511 Kodi 15.2
I went into google account and removed all Kodi references and then reauthorized my living room Kodi machine. That one worked for that use session.
Then later on when I went to bed I tried to use my laptop in my bedroom with same versions of software and after authorizing that one I get the unknown kind error.
Then this morning I tried to use my living room pc and it didn't work either...
09:04:29 T:6624  NOTICE: special://profile/ is mapped to: special://masterprofile/
09:04:29 T:6624  NOTICE: -----------------------------------------------------------------------
09:04:29 T:6624  NOTICE: Starting Kodi (15.2 Git:20151019-02e7013). Platform: Windows NT x86 32-bit
09:04:29 T:6624  NOTICE: Using Release Kodi x32 build
09:04:29 T:6624  NOTICE: Kodi compiled Oct 19 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
09:04:29 T:6624  NOTICE: Running on Gigabyte Technology Co., Ltd. EX58-UD3R with Windows 10, kernel: Windows NT x86 64-bit version 10.0
09:04:29 T:6624  NOTICE: Host CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz, 8 cores available
09:04:29 T:6624  NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
09:04:29 T:6624  NOTICE: Running with restricted rights
09:04:29 T:6624  NOTICE: Aero is enabled
09:04:29 T:6624  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
09:04:29 T:6624  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
09:04:29 T:6624  NOTICE: special://masterprofile/ is mapped to: C:\Users\quick\AppData\Roaming\Kodi\userdata
09:04:29 T:6624  NOTICE: special://home/ is mapped to: C:\Users\quick\AppData\Roaming\Kodi\
09:04:29 T:6624  NOTICE: special://temp/ is mapped to: C:\Users\quick\AppData\Roaming\Kodi\cache
09:04:29 T:6624  NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
09:04:29 T:6624  NOTICE: Local hostname: MEDIABOX-WIN10
09:04:29 T:6624  NOTICE: Log File is located: C:\Users\quick\AppData\Roaming\Kodi\kodi.log
09:04:29 T:6624  NOTICE: load settings...
09:04:29 T:1524  NOTICE: Thread CWin32PowerStateWorker start, auto delete: false
09:04:29 T:6624 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
09:04:29 T:6624 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
09:04:29 T:6624  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
09:04:29 T:6624  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
09:04:29 T:6624  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <videodatabase>
                                                <type>mysql</type>
                                                <host>192.168.1.100</host>
                                                <port>3306</port>
                                                <user>xxxx</user>
                                                <pass>xxxx</pass>
                                                <name>mastervideo</name>
                                              </videodatabase>
                                              <musicdatabase>
                                                <type>mysql</type>
                                                <port>3306</port>
                                                <user>xxxx</user>
                                                <pass>xxxx</pass>
                                                <name>mastermusic</name>
                                              </musicdatabase>
                                              <splash>false</splash>
                                            </advancedsettings>
09:04:29 T:6624 WARNING: VIDEO database configuration is experimental.
09:04:29 T:6624  NOTICE: Default DVD Player: dvdplayer
09:04:29 T:6624  NOTICE: Default Video Player: dvdplayer
09:04:29 T:6624  NOTICE: Default Audio Player: paplayer
09:04:29 T:6624  NOTICE: Disabled debug logging due to GUI setting. Level 0.
09:04:29 T:6624  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
09:04:29 T:6624  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
09:04:29 T:6624  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:04:29 T:6624  NOTICE: Loaded playercorefactory configuration
09:04:29 T:6624  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:04:29 T:6624  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:04:29 T:12984  NOTICE: Thread ActiveAE start, auto delete: false
09:04:29 T:2380  NOTICE: Thread AESink start, auto delete: false
09:04:29 T:12984  NOTICE: Found 2 Lists of Devices
09:04:29 T:12984  NOTICE: Enumerated DIRECTSOUND devices:
09:04:29 T:12984  NOTICE:     Device 1
09:04:29 T:12984  NOTICE:         m_deviceName      : {54D707DD-30F1-40C6-AD14-730C9B51088D}
09:04:29 T:12984  NOTICE:         m_displayName     : HDMI - SONY AVAMP-4 (2- NVIDIA High Definition Audio)
09:04:29 T:12984  NOTICE:         m_displayNameExtra: DIRECTSOUND: SONY AVAMP-4 (2- NVIDIA High Definition Audio)
09:04:29 T:12984  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
09:04:29 T:12984  NOTICE:         m_channels        : FL,FR
09:04:29 T:12984  NOTICE:         m_sampleRates     : 48000
09:04:29 T:12984  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
09:04:29 T:12984  NOTICE:     Device 2
09:04:29 T:12984  NOTICE:         m_deviceName      : default
09:04:29 T:12984  NOTICE:         m_displayName     : default
09:04:29 T:12984  NOTICE: Enumerated WASAPI devices:
09:04:29 T:12984  NOTICE:         m_displayNameExtra: WASAPI: SONY AVAMP-4 (2- NVIDIA High Definition Audio)
09:04:29 T:12984  NOTICE:         m_channels        : FL,FR,FC,LFE,SL,SR,BL,BR
09:04:29 T:12984  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
09:04:29 T:12984  NOTICE:         m_dataFormats     : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
09:04:29 T:6624  NOTICE: Running database version Addons19
09:04:29 T:6624  NOTICE: ADDONS: Using repository repository.xbmc.org
09:04:29 T:6624  NOTICE: ADDONS: Using repository repository.xbmcadult
09:04:29 T:10620  NOTICE: Thread RemoteControl start, auto delete: false
09:04:29 T:13492  NOTICE: Thread JobWorker start, auto delete: true
09:04:29 T:6624  NOTICE: Found screen: HP w2007 Wide LCD Monitor on NVIDIA GeForce GTX 750 Ti, adapter 0.
09:04:29 T:6624  NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GTX 750 Ti, adapter 1.
09:04:29 T:6624  NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Secondary mode: 1680x1050@ 59.94 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 640x480@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 640x480@ 75.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x480@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Previous line repeats 2 times.
09:04:29 T:6624  NOTICE: Additional mode: 720x480@ 75.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x576@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x576@ 75.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 800x600@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 800x600@ 75.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 75.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x720@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 75.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 59.94 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 59.94 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 59.94 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x720@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 60.00 #2 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 800x600@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1024x768@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x864@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x768@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x800@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x960@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1280x1024@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1360x768@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1366x768@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x900@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1600x1024@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1680x1050@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x720@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1152x720@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 59.94 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 23.98 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 24.00 - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 29.97i - Full Screen
09:04:29 T:6624  NOTICE: Additional mode: 1440x900@ 30.00i - Full Screen
09:04:29 T:6624  NOTICE: Checking resolution 16
09:04:29 T:2420  NOTICE: Thread PeripBusCEC start, auto delete: false
09:04:29 T:3064  NOTICE: Thread PeripBusUSB start, auto delete: false
09:04:29 T:6624  NOTICE: Running database version ViewModes6
09:04:29 T:6624  NOTICE: Running database version Textures13
09:04:30 T:6624  NOTICE: Running database version mastermusic52
09:04:30 T:6624  NOTICE: Running database version mastervideo93
09:04:30 T:6624  NOTICE: Running database version TV29
09:04:30 T:6624  NOTICE: Running database version Epg10
09:04:30 T:6624 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
09:04:30 T:6624 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
09:04:30 T:6624 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
09:04:30 T:6624 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
09:04:30 T:2972  NOTICE: Thread LanguageInvoker start, auto delete: false
09:04:30 T:6624  NOTICE: Previous line repeats 5 times.
09:04:30 T:6624  NOTICE: CApplication::UpdateLibraries: Starting video library startup scan
09:04:30 T:14332  NOTICE: Thread JobWorker start, auto delete: true
09:04:30 T:6624  NOTICE: initialize done
09:04:30 T:2704  NOTICE: Thread LanguageInvoker start, auto delete: false
09:04:30 T:6624  NOTICE: Running the application...
09:04:30 T:2972  NOTICE: -->Python Interpreter Initialized<--
09:04:30 T:9516  NOTICE: Thread JobWorker start, auto delete: true
09:04:30 T:10236  NOTICE: -->Python Interpreter Initialized<--
09:04:30 T:6624  NOTICE: Webserver: Starting...
09:04:30 T:6624  NOTICE: WebServer: Started the webserver
09:04:30 T:6624  NOTICE: starting upnp client
09:04:30 T:6624  NOTICE: starting upnp server
09:04:30 T:6624  NOTICE: starting upnp controller
09:04:30 T:6624  NOTICE: starting upnp renderer
09:04:30 T:6624  NOTICE: ES: Starting event server
09:04:30 T:2744  NOTICE: Thread EventServer start, auto delete: false
09:04:30 T:2744  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
09:04:30 T:2744  NOTICE: UDP: Listening on port 9777
09:04:30 T:2244  NOTICE: Thread TCPServer start, auto delete: false
09:04:30 T:14332  NOTICE: VideoInfoScanner: Starting scan ..
09:04:30 T:10992  NOTICE: Thread JobWorker start, auto delete: true
09:04:30 T:7396  NOTICE: Thread RSSReader start, auto delete: false
09:04:31 T:2704  NOTICE:  StorageServer Module loaded RUN
09:04:31 T:2704  NOTICE: StorageClient-2.5.4 Starting server
09:04:31 T:11372  NOTICE: script.grab.fanart: Grab Fanart Service Started
09:04:37 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Fighter Pilot - Operation Red Flag (2004)/Fighter Pilot Air Show (1900)/Fighter Pilot Air Show (1900).avi', it won't be added to the library.
09:04:37 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Fighter Pilot - Operation Red Flag (2004)/Fighter Pilot Making Of the Movie (1900)/Fighter Pilot Making Of the Movie (1900).avi', it won't be added to the library.
09:04:38 T:14332 WARNING: No information found for item 'stack://smb://MEDIABOX-WIN10/Movies 1/G3 Live in Concert (1996–)/G3 Live in Concert (1996–)part1.wmv , smb://MEDIABOX-WIN10/Movies 1/G3 Live in Concert (1996–)/G3 Live in Concert (1996–)part2.wmv , smb://MEDIABOX-WIN10/Movies 1/G3 Live in Concert (1996–)/G3 Live in Concert (1996–)part3.wmv', it won't be added to the library.
09:04:40 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Ice Age Collection/Ice Age 3, Dawn of the Dinosaurs (2009)/Ice Age - Dawn of the Dinosaurs Bouns1/Ice Age - Dawn of the Dinosaurs Bouns1.wmv', it won't be added to the library.
09:04:40 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Ice Age Collection/Ice Age 3, Dawn of the Dinosaurs (2009)/Ice Age - Dawn of the Dinosaurs Bouns2/Ice Age - Dawn of the Dinosaurs Bouns2.wmv', it won't be added to the library.
09:04:41 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Adventures in Post-Production/Adventures.in.Post-Production.mkv', it won't be added to the library.
09:04:41 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Iconic Props/Iconic.Props.mkv', it won't be added to the library.
09:04:41 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Indiana Jones and the Creepy Crawlies/Indiana.Jones.and.the.Creepy.Crawlies.mkv', it won't be added to the library.
09:04:41 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Indys Friends and Enemies/Indys.Friends.and.Enemies.mkv', it won't be added to the library.
09:04:41 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Indys Women/Indys.Women.mkv', it won't be added to the library.
09:04:41 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Making the Films Part 1/Making.the.Films.Part.1.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Making the Films Part 2/Making.the.Films.Part.2.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Making the Films Part 3/Making.the.Films.Part.3.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Making the Films Part 4/Making.the.Films.Part.4.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/On Set with Raiders of the Lost Ark/On.Set.with.Raiders.of.the.Lost.Ark.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Effects of Indy/The.Effects.of.Indy.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Light and Magic of Indiana Jones/The.Light.and.Magic.of.Indiana.Jones.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Making of TKOTCS/The.Making.of.TKOTCS.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Melting Face/The.Melting.Face.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Music of Indiana Jones/The.Music.of.Indiana.Jones.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Sound of Indiana Jones/The.Sound.of.Indiana.Jones.mkv', it won't be added to the library.
09:04:42 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/The Stunts of Indiana Jones/The.Stunts.of.Indiana.Jones.mkv', it won't be added to the library.
09:04:43 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Movies 1/Indiana Jones The Complete Adventures/Indiana Jones The Complete Adventures Extras/Travel with Indiana Jones Locations/Travel.with.Indiana.Jones.Locations.mkv', it won't be added to the library.
09:04:46 T:10780  NOTICE: Thread LanguageInvoker start, auto delete: false
09:04:46 T:10780  NOTICE: -->Python Interpreter Initialized<--
09:04:46 T:10780  NOTICE: [plugin.video.youtube] Running: YouTube (5.1.12) on Isengard (15.2) with Python 2.7.8
09:04:48 T:6256  NOTICE: Thread BackgroundLoader start, auto delete: false
09:04:50 T:14332 WARNING: VIDEO::CVideoInfoScanner::Process directory 'smb://MEDIABOX-WIN10/Movies 3/Avengers Collection/Iron Man 3 (2013)/' does not exist - skipping scan.
09:04:50 T:14100  NOTICE: Thread LanguageInvoker start, auto delete: false
09:04:50 T:14100  NOTICE: -->Python Interpreter Initialized<--
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Dream Theater - Breaking The Fourth Wall (2014)/Dream Theater - Breaking The Fourth Wall (2014).mkv', it won't be added to the library.
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Dream Theater - Breaking The Fourth Wall (2014) [Unknown] [voted 5.3] [Musical]/Disc 1/VIDEO_TS/VIDEO_TS.IFO', it won't be added to the library.
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Dream Theater - Breaking The Fourth Wall (2014) [Unknown] [voted 5.3] [Musical]/Disc 2/VIDEO_TS/VIDEO_TS.IFO', it won't be added to the library.
09:04:50 T:14100  NOTICE: [plugin.video.youtube] Running: YouTube (5.1.12) on Isengard (15.2) with Python 2.7.8
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Joe Satriani, Live in Paris - I Just Wanna Rock (2010)/Joe Satriani, Live in Paris - I Just Wanna Rock (2010).avi', it won't be added to the library.
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Kiss - Live In Nurburgring (2012)/Kiss - Live In Nurburgring (2012).mkv', it won't be added to the library.
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Lacuna Coil @ Loudpark 2007/Lacuna Coil @ Loudpark 2007.wmv', it won't be added to the library.
09:04:50 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Liquid Tension Experiment/LA/L.A. - Live.avi', it won't be added to the library.
09:04:50 T:14332 WARNING: No information found for item 'stack://smb://MEDIABOX-WIN10/Music Videos/Liquid Tension Experiment/NYC/Liquid Tension Experiment LIVE IN NYC [Part 1 of 3].mkv , smb://MEDIABOX-WIN10/Music Videos/Liquid Tension Experiment/NYC/Liquid Tension Experiment LIVE IN NYC [Part 2 of 3].mkv , smb://MEDIABOX-WIN10/Music Videos/Liquid Tension Experiment/NYC/Liquid Tension Experiment LIVE IN NYC [Part 3 of 3].mkv', it won't be added to the library.
09:04:51 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/Yanni/Yanni Live! The Concert Event (2006)/Yanni Live! The Concert Event (2006).mkv', it won't be added to the library.
09:04:51 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Music Videos/ZZ Top Live from Texas (2008)/ZZ Top Live from Texas (2008).wmv', it won't be added to the library.
09:04:51 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Nature Collection/Earth, The Power of the Planet (2007)/', it won't be added to the library.
09:04:51 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/Nature Collection/Island of Lemurs, Madagascar (2014)/', it won't be added to the library.
09:04:51 T:14100   ERROR: [plugin.video.youtube] Unknown kind ''
09:04:53 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/TV 1/Youtube Videos/', it won't be added to the library.
09:04:54 T:14332 WARNING: No information found for item 'smb://MEDIABOX-WIN10/TV 2/Shogun (Mini-Series 1980) (1980)/', it won't be added to the library.
09:04:54 T:6624   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youtube/subscriptions/list/
09:04:54 T:6624   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/subscriptions/list/) failed
09:04:54 T:4680  NOTICE: Thread BackgroundLoader start, auto delete: false
09:04:54 T:14332  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:23
09:04:54 T:12484  NOTICE: Thread LanguageInvoker start, auto delete: false
09:04:54 T:12484  NOTICE: -->Python Interpreter Initialized<--
09:04:55 T:12484  NOTICE: [plugin.video.youtube] Running: YouTube (5.1.12) on Isengard (15.2) with Python 2.7.8
09:04:55 T:6708  NOTICE: Thread BackgroundLoader start, auto delete: false
09:04:57 T:1708  NOTICE: Thread LanguageInvoker start, auto delete: false
09:04:57 T:1708  NOTICE: -->Python Interpreter Initialized<--
09:04:57 T:1708  NOTICE: [plugin.video.youtube] Running: YouTube (5.1.12) on Isengard (15.2) with Python 2.7.8
09:04:58 T:1708   ERROR: [plugin.video.youtube] Unknown kind ''
09:05:00 T:6624   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youtube/subscriptions/list/
09:05:00 T:6624   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/subscriptions/list/) failed
09:05:00 T:6620  NOTICE: Thread BackgroundLoader start, auto delete: false
09:05:56 T:6932  NOTICE: Thread JobWorker start, auto delete: true
09:06:08 T:11816  NOTICE: Previous line repeats 1 times.
09:06:08 T:11816  NOTICE: Thread BackgroundLoader start, auto delete: false
09:13:29 T:11400  NOTICE: Previous line repeats 2 times.
09:13:29 T:11400  NOTICE: Thread JobWorker start, auto delete: true
