If it would help, i can create a repository from 5.1.16 and let ppl pull from that then commit. I don't mind maintaining it. I just can't program at the moment. I have no issue with being the maintainer.
Let me know.
Jeff
I have download the 5.1.16 and push the fix also to the repository of Kodi Team, for now they are talking about what are doing. If you want be the new maintainer, please create a new Thread and send everything to the Kodi Team
nah i was just offering, i can't code so i would be only able to contribute as a manager per say. Since it appears i'm a little in the dark on how the whole process works, it would probably be best that I not do it, but if it would help with this add-on i'd be willing to learn.
Jeff
edited: to make more sense...
Youtube 5.1.20.1 worked for me thanks
Hello just a qusetion please,
From the addons i removed plugin.youtube and also script.youtube
From the user data i removed the plugin.youtube
After installing the youtube addon both plugins.youtube came in my system, but i cannot see the
Script.youtube but still youtube works fine
what issue can caouse without the script.youtube file ? Thanks
Thank you all for 5.1.20.1 it worked like a charm
20.1 still doesnt work for me, no videos in My Subscriptions etc etc
thank you guys the last version "5.1.20.1" is working good for me too
Where can i find that version?
I have installed the 5.1.20.1. What are the rest of you seeing on the "Live" screen? I see one hummingbird video (which pretends like it is playing but only displays a brownish color when I click on it) then a bunch of really old streams that are long since dead (and throw errors if I try to watch)
Ok...i try this 5.1.20.1................ Usually i use youtube whitout logeed in and i have my API keys if i need............... i need only to uninstall my previous version and i need to uninstall manually by deleting all folder/files from my Pi2 OSMC because i have a lot of depencies used by youtube
*EDIT*
Continue to obtain same bug:
Reach a channel from HomePage bookmark there's will be obtain an empty page and no video in list................ apparently all work if i reach the same channel by search function.
Apparently from home page not a reload or refresh of video list on a channel it's be obtain.....................
(2016-02-27, 16:23)sector9 Wrote: [ -> ]I have installed the 5.1.20.1. What are the rest of you seeing on the "Live" screen? I see one hummingbird video (which pretends like it is playing but only displays a brownish color when I click on it) then a bunch of really old streams that are long since dead (and throw errors if I try to watch)
There is a itag 91 error, it is not defined in youtube addon. Try again and then you can see live video.
I cannot find about itag 91, it may undocumented.
According to my stupid bug... i don't know if it's a addons bug or it's possibly to it's a osmc bug:
Apparently inside the youtube addons there's present some "hidden" function to force a refresh the video list ??
From bookmark some similar has been launched:
<favourite name="Cinemassacre" thumb="https://yt3.ggpht.com/-1R7HFhVqgUE/AAAAAAAAAAI/AAAAAAAAAAA/InI3d_ZtFOo/s240-c-k-no-mo/photo.jpg">ActivateWindow(10025,"plugin://plugin.video.youtube/channel/UC0M0rxSz3IF0CsSour1iWmw/",return)</favourite>
The youtube addons has been launched correctly but the video present in channel it's not be refresh and if you have not reach previously the same channel by "search" function you obtain an empty page like channel have no video.
I have try to navigate the "left" menĂ¹ of osmc....... it's present a refresh button but it's disabled........ apparently the only method it's leave the bookmark and reach all channel using only the search function and only in this mode can will be otain the upgraded list of video it's present in channel.
Someone has this similar problems whit same version of youtube addons or not ?? Or it's a osmc bug obtain whit the latest upgrade (like pass to kodi 16.0 for example) ?
*EDIT*
Apparently if i reach the same channel from firefox from windows 7 the url it's totally different:
https://www.youtube.com/user/JamesNintendoNerd/featured
and here for video list:
https://www.youtube.com/user/JamesNintendoNerd/videos
But i don't thinks this is that problems............
(2016-02-27, 14:30)Kolifanes Wrote: [ -> ]Please download YouTube 5.1.20.1 from here
https://github.com/Kolifanes/plugin.vide...1.20.1.zip
And report if this release is working for you or not.
Please remember always to delete the folder on your userdata plugin.video.youtube. You can found the location here http://kodi.wiki/view/Userdata
Other things like remove the addon etc. Aren't necessary.
Thanks for collaboration
Worked for me! Running Jarvis v3
