OOOOOOOOOOOOOOHHHHHHHHH YEEEEESSS! Apparently i have RESOLVED the BUG whit video list on channel not refresh when a youtube addo-on it's launched from favourites home page of kodi !!!
I try to explain how it's work:
I have look my "favourites.xml" here -> /home/osmc/.kodi/userdata
I have make a search and i have add a favourites directly from search result........ i have add a italian channel called "Momenti di qualità". From the search result this is the result it be added to xml file:
<favourite name="Momenti di Qualità" thumb="https://yt3.ggpht.com/-WC8hPMQB7VU/AAAAAAAAAAI/AAAAAAAAAAA/xmFhtSqj0hQ/s240-c-k-no/photo.jpg">ActivateWindow(10025,"plugin://plugin.video.youtube/channel/UCkpyMmNsb7Qb_G-SUn7fM0A/",return)</favourite>
On same thread some days i have noticed the same problems.......... on Windows 7 using firefox when you try to open same exact link it's been obtain a totally different link for the same channel........... i have tryed and i have obtain this:
https://www.youtube.com/user/momentidiqualita
At this point i have need to manually add this NEWEST line to my "favourites.xml":
<favourite name="Momenti di Qualità-Prova" thumb="https://yt3.ggpht.com/-WC8hPMQB7VU/AAAAAAAAAAI/AAAAAAAAAAA/xmFhtSqj0hQ/s240-c-k-no/photo.jpg">ActivateWindow(10025,"plugin://plugin.video.youtube/user/momentidiqualita/",return)</favourite>
I have saved xml on Pi2......... and i have try to launch this link from home of osmc and.............. OOOOOHHH YES!! Only now all video on CHANNEL it's been refreshed whitout a problems!!!
I thinks this is a BUG on this latest version of youtube add-on....... i thinks there's no or somethings goes in corruption when the add-on get channel link from the search result or similar things, i thinks there's somethigs goes in error when the link it's been converted or similar!!!
I don't know nothings how i can fix this to SOURCE or similar.................... if someone can develope or check this problems in this source please try to make a patch or similar.
Thanks in advance................... Ah.............. PLEASE:
Make sure to make useless this my segnalation..................... someone confirm to me if or not have this my same problems........ it's two or three times i try to search a myself solution and now apparently somethigs i found please not trash it
*EDIT*
Only for this channel ->
http://www.youtube.com/channel/UCBhPrOyiOcbRQZSJDfJomxA
I can't obtain the /user/ link and i can't modify my xml favourites file......... damn.............
