(2016-03-04, 04:30)nickr Wrote: [ -> ]Would you please take note of the fact that ........ is not part of the English language, it makes your posts awfully hard to read.
Try to know.... we can't be all native english speaker
but trust me i try to wrote english better i can do every time but i know my english it's not very good.... at school my max vote it's 4
I know it's useless but if you thinks it's better i can try to explain the problems using italian
*Back to IT*
I have a stupid question..................... every time i upgrade the 5.1.20.x release manually from picked zip here......... i need every time to remove the data profile or not ?
(2016-03-04, 19:57)jdf76 Wrote: [ -> ]ok lets just go all the way then, Lets delete
$KODI/userdata/addon_data/plugin.video.youtube folder
$KODI/addons/plugin.video.youtube
restart kodi.
What that will essentially do is delete youtube from your system completely.
Then reinstall the plugin from https://github.com/Kolifanes/plugin.vide...e/releases
you should be gold at that point, if it still doesn't work go ahead and get the kodi.log file.
see http://kodi.wiki/view/Log_file/Easy
Jeff
This solution worked for me. Greatly appreciate your help.
Thx
I didn't have to and I upgraded from 5.1.17
Edit: Nevermind i just did, originally it didn't but i now had to log out and log back in and it worked fine.
Jeff
(2016-03-05, 03:11)DjDiabolik Wrote: [ -> ] (2016-03-04, 04:30)nickr Wrote: [ -> ]Would you please take note of the fact that ........ is not part of the English language, it makes your posts awfully hard to read.
Try to know.... we can't be all native english speaker but trust me i try to wrote english better i can do every time but i know my english it's not very good.... at school my max vote it's 4
*Back to IT*
Where can I find this folder on the RP? Using OpenElec.
restart kodi.
Jeff
(2016-03-04, 18:51)ashlar Wrote: [ -> ] (2016-03-04, 18:05)un1versal Wrote: [ -> ]If theres several distinct API keys in use on this addon alone, its possible to add, but it wouldn't be a trivial update like weather add-on similar update, but it would be possible.
Google must be strapped for bandwidth and cash these days.
Theoretically there's only one set of keys that's necessary to input. It's a set, so more than one string. But I think that a competent programmer should be able to do it quite easily (it's a matter of taking the in put of a couple of settings requesters and placing it in the right place in the configuration file). If I'm wrong, excuse me, I usually refrain from expressing thoughts about stuff like this, not being a programmer. But this, conceptually at least, seems really easy.
Yea It should be possible, but like I said its not as simple as the weather addon type similar change/support.
Im not a programmer either but I read the code for the weather addons.
Does this new plugin break other plugins which rely on the youtube addon? I don't want to fix youtube just to have those break.
(2016-03-05, 17:31)LFCFAN Wrote: [ -> ] (2016-03-05, 17:06)mattmartinolc Wrote: [ -> ]Does this new plugin break other plugins which rely on the youtube addon? I don't want to fix youtube just to have those break.
NO, it won't.
Cool. Because I tried another solution from another thread and Youtube did indeed work again but every addon that uses youtube like Pro Sport stopped working.
restart kodi.
Jeff
What's up Jeff,
I see these instructions all over the place but I'm still having problems getting you tube to work. I have a fire stick with Kodi loaded on it and plugged to tv. When I'm in it I'm able to remove old software (at least I think) and when I go to add source and type in that github address I can't unzip it later since it leads to nothing. Can you provide me step by step instruction on how to do this from fire stick? I don't know anything about computers and my wife is harassing me to get this to work. Your help is greatly appreciated.
(2016-03-05, 19:59)Chill72 Wrote: [ -> ] (2016-03-04, 19:57)jdf76 Wrote: [ -> ]ok lets just go all the way then, Lets delete
restart kodi.
Jeff
What's up Jeff,
Download the file on another computer and access it through your network. Use "Install from ZIP file" in Kodi.
I sent a pull request to Kolifanes repository... all he has to do is commit and provide a new zip file.
Here's the new feature.
ver 5.1.20.4 - API key in add-on settings
API key is now configurable from add-on settings. Users that have valid API key can now enter their key from add-on settings dialog. API Key from version 5.1.20.3 is never lost if end-user makes a change since version 5.1.20.3 API key is default value in settings.xml file. The youtube-tv key in login_client.py cannot be changed. Only kodi-quota, kodi-fallback and kodi-xx version will change when end-user enters their API key. If end-user enters a non-working key or makes a mistake when entering their key, the youtube add-on will continue to work if the end-user selects 'Default' button in the add-on settings since that will activate the default API key.
This new feature is safer for less experienced end-users since they can enter a valid API key without any python programming knowledge. All end-users who are currently using their own API key will like this new change as well because they will not need to keep editing login_client.py file and future updates should not change their API key setting.
Thanks @
misty01. Sounds good. I recommend people use yatse or kore to add their api keys cos you should be able to paste, rather than risk a typo.
(2016-03-05, 22:32)blueribb Wrote: [ -> ] (2016-03-05, 19:59)Chill72 Wrote: [ -> ] (2016-03-04, 19:57)jdf76 Wrote: [ -> ]ok lets just go all the way then, Lets delete
restart kodi.
Jeff
What's up Jeff,
What? I need a computer for this. My wife has iMac pro book. How do I do all this? Set up a network? What does that mean? Can you write me a step by step instruction starting with turning on the computer. I know nothing about computers but I can follow instruction. Last working you tube I got was from the stick alone (bro mix repo) and I didn't need another computer.
