10:56:15 T:6720 DEBUG: CPythonInvoker(11, C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py): start processing
10:56:15 T:6720 NOTICE: -->Python Interpreter Initialized<--
10:56:15 T:6720 DEBUG: CPythonInvoker(11, C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py): the source file to load is "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py"
10:56:15 T:6720 DEBUG: CPythonInvoker(11, C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py): setting the Python path to C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube;C:\Users\cristian\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
10:56:15 T:6720 DEBUG: CPythonInvoker(11, C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py): entering source directory C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube
10:56:15 T:6720 DEBUG: CPythonInvoker(11, C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.1.0 of the xbmc.python api
10:56:16 T:7208 DEBUG: DialogProgress::StartModal called
10:56:16 T:6720 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object has no attribute '__getitem__'
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\default.py", line 7, in <module>
runner.run(__provider__)
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\runner.py", line 16, in run
__RUNNER__.run(provider, context)
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\impl\xbmc\xbmc_runner.py", line 27, in run
results = provider.navigate(context)
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\abstract_provider.py", line 106, in navigate
result = method(context, re_match)
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\kodion\register_provider_path.py", line 12, in wrapper
return func(*args, **kwargs)
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\provider.py", line 241, in _on_play
return yt_play.play_video(self, context, re_match)
File "C:\Users\cristian\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube\helper\yt_play.py", line 21, in play_video
video_item = VideoItem(video_id, video_stream['url'])
TypeError: 'NoneType' object has no attribute '__getitem__'
10:56:16 T:7208 DEBUG: ------ Window Init (DialogProgress.xml) ------
10:56:16 T:7208 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
10:56:17 T:6720 INFO: Python script stopped
10:56:17 T:6720 DEBUG: Thread LanguageInvoker 6720 terminating
10:56:17 T:7208 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
10:56:17 T:7208 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
10:56:17 T:7208 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=trDuiMOg6B0]
10:56:17 T:7208 DEBUG: Playlist Player: no more playable items... aborting playback
10:56:17 T:1700 NOTICE: Thread BackgroundLoader start, auto delete: false
10:56:17 T:1700 DEBUG: Thread BackgroundLoader 1700 terminating
10:56:17 T:7208 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
10:56:20 T:7208 DEBUG: ------ Window Deinit (Pointer.xml) ------
10:56:20 T:7208 DEBUG: ------ Window Init (Pointer.xml) ------
10:56:22 T:7208 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
10:56:23 T:7208 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
10:56:23 T:7208 DEBUG: CApplication::OnKey: alt-leftalt (0x4f0d4) pressed, action is
10:56:23 T:7208 DEBUG: ------ Window Deinit (Pointer.xml) ------
10:56:23 T:7208 DEBUG: CWinEventsWin32::WndProcWindow is active
10:56:23 T:7208 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
