Full Version: YouTube (IMPORTANT - READ FIRST POST)
(2015-01-14, 20:07)bromix Wrote: [ -> ][In the beta6 go to 'Addon-Settings' -> 'Advanced' and enabled 'Support alternative player'
Hi Bromix,
This new setting does bring up a new "play with" option in the context menu. However, selecting it triggers nothing other than closing the whole context menu. Then I rolled back to 5.0.1.beta 6 (the only version I was allowed to choose from) to test if I messed up something, and found that the old "play using" option was still working perfectly everywhere in the old version. Perhaps you might want to set up an external player in playercorefactory.xml to verify this? Are "play with" and "play using" the same thing in Kodi?
(2015-01-15, 00:05)Gazzyb Wrote: [ -> ]
(2015-01-14, 13:49)gotiuser01 Wrote: [ -> ]I use MPC-HC + ffdshow + a very good Avisynth script to do frame interpolation and watch some YouTube videos at 60fps (mainly for sports and live performance videos). They look a whole lot smoother and more realistic at higher frame rate Smile To achieive the same effect with SVP+DSplayer it takes 2x-3x the CPU power ...
Any chance you could give a detailed description of how to do this.
Not having 1080P and 60FPS is really annoying me (which is no fault of Bromix or this addon)
I'll send you a PM to keep the thread clean.Wink
(2015-01-13, 14:45)bromix Wrote: [ -> ]
(2015-01-13, 14:17)yonika Wrote: [ -> ]I'm not sure I understand what you mean by saying it makes no sense and that I put a damaged engine in another vehicle.
You said that it might be my system and that we need to check without any other addons so I took a clean Yosemite install on another machine and tried it as well.
This eliminates the thought that it relates to the other addon,
Eliminates the thought that this is only my system.
And leaves us with the possibilities that it's a bug in OS X/Kodi/Python 2.6.5(which is compiled into kodi)
Jonathan
I thought you would try another OS (the version from before, because Yosemite is more an update) Wink On the same system/platform. For example I work for a software company and from time to time we encounter problems on a windows 8.1 but not on windows 8...or even windows 7. SO we have to test and try to exclude the OSes which are not the problem and then start from there. In your case Yosemite. Yosemite has at the current moment a not so good standpoint on the market for apple. A lot of customers are complaining about the new design and the bugs (this is today more or less normal) and the system is only a few month old. In my case I have the 2 Minute freeze bug while installing Yosemite and no one has a correct solution for that.
If you search in this forum you will find some errors regarding Mac OS X systems which lock very similar to the error you have. So we should (If possible) test if its more a problem based on the OS or are we hunting ghosts. For my experience (and I thought you couldn't play any video, but you could) because the errors happen randomly seems for my not a bug in a addon it self (because the script is already finished).
For what it's worth, I'm experiencing the exact same problems as Yonika reported, but on the latest version of iOS (iPhone 4S, iOS 8.1.2, Kodi 14.0). Kodi crashing completely at random times when using the Youtube addon. All other addons working fine. Kodi log file doesn't mention anything relevant (even with debug enabled) and the iOS crash log is always containing the same segmentation fault (seems to be always happening in the LanguageInvoker thread)...
All my other devices (Windows, Android) are running perfectly fine...
(2015-01-15, 15:44)yellowz Wrote: [ -> ]For what it's worth, I'm experiencing the exact same problems as Yonika reported, but on the latest version of iOS (iPhone 4S, iOS 8.1.2, Kodi 14.0). Kodi crashing completely at random times when using the Youtube addon. All other addons working fine. Kodi log file doesn't mention anything relevant (even with debug enabled) and the iOS crash log is always containing the same segmentation fault (seems to be always happening in the LanguageInvoker thread)...
If possible, can you provide a complete log via pastebin.com
Maybe we can see something similar.
(2015-01-15, 15:59)bromix Wrote: [ -> ]
I had recently downgraded to Gotham 13.2-3 (for other reasons), but it is crashing there as well. Used 5.0.4~beta6 from your repo.
The xbmc log can be found here:
xbmc log
and the iOS crash log here:
iOS crash log
The xbmc log is containing some errors with respect to my internet connection, but those didn't lead to the crash eventually...
(2015-01-15, 18:24)yellowz Wrote: [ -> ]I had recently downgraded to Gotham 13.2-3 (for other reasons), but it is crashing there as well. Used 5.0.4~beta6 from your repo.
xbmc log
iOS crash log
Mhmmm...it's possible that the connection problems are an indicator:
http://arstechnica.com/apple/2015/01/why...to-fix-it/
http://www.iphonehacks.com/2014/09/fix-i...blems.html
I have found more of them Wink
Your system can't resolve any hostname and I'm not catching the exception in this part of code. I will update the part of the code, so the addon won't crash. Because it's possible that the exception has some side-effects if some resources are not freed correctly. This could be (I repeat: could be) the error we are seeing on the Mac OS X because of undefined states of objects after an exception. So to exclude this thesis I will update and PR the 5.0.4 (final).
You should look if you can find something to get your DNS resolving working. I also remembered a similar problem with Win 8 + DNS in this thread.
Updated to version 5.0.3, Vevo videos not playing anymore (again!). Anyone also encountered this issue?
(2015-01-15, 21:59)schudel Wrote: [ -> ]Updated to version 5.0.3, Vevo videos not playing anymore (again!). Anyone also encountered this issue?
See FAQ on first page...log please and link to the video (again!). Are you getting a message or nothing happens? Some VEVO videos are geo-blocked.
I am experiencing a bizarre bug.
I can only watch videos once. I cannot watch them a second time.
No issue playing the first time. Just the second time.
Any idea as to the cause?
(2015-01-15, 22:21)Wigguslong Wrote: [ -> ]I am experiencing a bizarre bug.
Logs please! Smile
(2015-01-15, 22:22)bromix Wrote: [ -> ]
Logs please! Smile
Sorry, how do I display logs? Thanks.
I can no longer play vevo videos, as of around a week ago. This happened once before, but it was a long time ago and can't remeber what the fix was. Any help would be appreciated.
Hello I have the same problem for vevo
here is the log
belgium
sorry very long
my English is not very
  good
21:28:32 T:2649426752 NOTICE: CDVDPlayer::OnExit()
21:28:32 T:2649426752 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:28:32 T:3063105280 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=cmE_aahc448]
21:28:32 T:2649426752 NOTICE: Thread BackgroundLoader start, auto delete: false
21:28:32 T:3063105280 NOTICE: CDVDPlayer::CloseFile()
21:28:32 T:3063105280 NOTICE: DVDPlayer: waiting for threads to exit
21:28:32 T:3063105280 NOTICE: DVDPlayer: finished waiting
21:28:33 T:2790009664 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:28:51 T:2790009664 NOTICE: Thread FileCache start, auto delete: false
21:29:44 T:2823879488 NOTICE: Previous line repeats 1 times.
21:29:44 T:2823879488 NOTICE: ES: Client XBMC Constellation from 192.168.1.24 timed out
21:29:50 T:2665171776 NOTICE: Thread PAPlayer start, auto delete: false
21:29:50 T:2682256192 NOTICE: Thread JobWorker start, auto delete: true
21:30:23 T:2823879488 NOTICE: Previous line repeats 2 times.
21:30:23 T:2823879488 NOTICE: ES: Incoming connection from XBMC Constellation
21:30:24 T:2749745984 NOTICE: Thread JobWorker start, auto delete: true
21:30:37 T:2823879488 NOTICE: ES: Incoming connection from XBMC Constellation
21:30:38 T:2790009664 NOTICE: Thread PAPlayer start, auto delete: false
21:30:38 T:2773224256 NOTICE: Thread JobWorker start, auto delete: true
21:30:41 T:2815486784 NOTICE: Previous line repeats 2 times.
21:30:41 T:2815486784 WARNING: Create - Unsupported protocol(pipe) in pipe://2/
21:30:41 T:2815486784 ERROR: Exists - Error checking for pipe://2/
21:30:41 T:2823879488 NOTICE: ES: Incoming connection from XBMC Constellation
21:30:42 T:2815486784 WARNING: Create - Unsupported protocol(pipe) in pipe://2/
21:30:42 T:2815486784 ERROR: Exists - Error checking for pipe://2/
21:30:52 T:2635799360 NOTICE: Thread LanguageInvoker start, auto delete: false
21:30:52 T:2635799360 NOTICE: -->Python Interpreter Initialized<--
21:30:52 T:2635799360 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:30:52 T:2635799360 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:30:52 T:2635799360 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:30:52 T:2635799360 WARNING: [plugin.video.youtube] DEPRECATED "plugin://plugin.video.youtube/?action=play_video&videoid=VHrLPs3_1Fs"
21:30:52 T:2635799360 WARNING: [plugin.video.youtube] USE INSTEAD "plugin://plugin.video.youtube/play/?video_id=VHrLPs3_1Fs"
21:30:53 T:2635799360 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:30:54 T:3063105280 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for https://r3---sn-cxab5jvh-cg0s.googlevide...485CFBCA43
21:30:54 T:3063105280 NOTICE: DVDPlayer: Opening: https://r3---sn-cxab5jvh-cg0s.googlevide...485CFBCA43
21:30:54 T:3063105280 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:30:54 T:2635799360 NOTICE: Thread DVDPlayer start, auto delete: false
21:30:54 T:2635799360 NOTICE: Creating InputStream
21:30:54 T:2635799360 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
21:30:54 T:2635799360 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
21:30:54 T:2635799360 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:30:54 T:2635799360 ERROR: Open - failed to open source <https://r3---sn-cxab5jvh-cg0s.googlevideo.com/videoplayback?requiressl=yes&sver=3&ratebypass=yes&id=o-AI4s3tPJvmCWigNiIAvFB212XJKn-yttDlcKNjnkLLHo&mv=m&mime=video/webm&sparams=dur,gcr,id,initcwndbps,ip,ipbits,itag,mime,mm,ms,mv,pl,ratebypass,requiressl,source,upn,expire&ip=81.247.6.232&fexp=900239,900718,907263,926410,927622,939977,9405646,9406250,941004,943917,947209,947225,948124,952302,952605,952901,955202,955301,957103,957105,957201,959701&ms=au&itag=43&pl=21&mt=1421353819&dur=0.000&key=yt5&upn=j0JX_8gckdA&source=youtube&ipbits=0&initcwndbps=1065000&gcr=be&expire=1421375453&mm=31&signature=8398393F7BEF1B0B56FC9BBE21CA1FA4B61547644ABB6.BAD8923E2EE60BBDD745CE1A3C565D485CFBCA43>
21:30:54 T:2635799360 ERROR: CDVDPlayer::OpenInputStream - error opening [https://r3---sn-cxab5jvh-cg0s.googlevide...485CFBCA43]
21:30:54 T:2635799360 NOTICE: CDVDPlayer::OnExit()
21:30:54 T:2635799360 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:30:54 T:3063105280 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?action=play_video&videoid=VHrLPs3_1Fs]
21:30:54 T:3063105280 NOTICE: CDVDPlayer::CloseFile()
21:30:54 T:3063105280 NOTICE: DVDPlayer: waiting for threads to exit
21:30:54 T:3063105280 NOTICE: DVDPlayer: finished waiting
21:30:54 T:2635799360 NOTICE: Thread LanguageInvoker start, auto delete: false
21:30:54 T:2635799360 NOTICE: -->Python Interpreter Initialized<--
21:30:55 T:2635799360 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:30:55 T:2635799360 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:30:55 T:2635799360 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:30:55 T:2635799360 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:30:56 T:2635799360 NOTICE: Thread FileCache start, auto delete: false
21:31:11 T:2673863488 NOTICE: Previous line repeats 1 times.
21:31:11 T:2673863488 ERROR: GetDirectory - Error getting
21:31:11 T:2635799360 NOTICE: Thread LanguageInvoker start, auto delete: false
21:31:11 T:2635799360 NOTICE: -->Python Interpreter Initialized<--
21:31:13 T:2635799360 NOTICE: Thread BackgroundLoader start, auto delete: false
21:31:15 T:3063105280 ERROR: GetDirectory - Error getting addons://sources/
21:31:15 T:3063105280 ERROR: CGUIMediaWindow::GetDirectory(addons://sources/) failed
21:31:15 T:2635799360 NOTICE: Thread BackgroundLoader start, auto delete: false
21:31:20 T:2635799360 NOTICE: Thread LanguageInvoker start, auto delete: false
21:31:20 T:2635799360 NOTICE: -->Python Interpreter Initialized<--
21:31:22 T:2635799360 NOTICE: Thread BackgroundLoader start, auto delete: false
21:31:31 T:2823879488 NOTICE: ES: Client XBMC Constellation from 192.168.1.24 timed out
21:32:01 T:2673863488 NOTICE: Previous line repeats 1 times.
21:32:01 T:2673863488 NOTICE: Thread JobWorker start, auto delete: true
21:32:01 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:32:15 T:2682256192 NOTICE: Previous line repeats 1 times.
21:32:15 T:2682256192 NOTICE: Thread JobWorker start, auto delete: true
21:32:18 T:2773224256 NOTICE: Previous line repeats 2 times.
21:32:18 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:32:28 T:2773224256 NOTICE: Previous line repeats 2 times.
21:32:28 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:28 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:28 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'sunshine live' from client '1': server error
21:32:28 T:2882534208 ERROR: EPG - Update - failed to update table 'sunshine live'
21:32:28 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR1 BW' from client '1': server error
21:32:28 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR1 BW'
21:32:28 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:32:28 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR1 RP' from client '1': server error
21:32:28 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR1 RP'
21:32:28 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR2' from client '1': server error
21:32:28 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR2'
21:32:29 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:29 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:29 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR3' from client '1': server error
21:32:29 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR3'
21:32:29 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR4 BW' from client '1': server error
21:32:29 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR4 BW'
21:32:29 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR4 RP' from client '1': server error
21:32:29 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR4 RP'
21:32:30 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:30 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:30 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'DASDING' from client '1': server error
21:32:30 T:2882534208 ERROR: EPG - Update - failed to update table 'DASDING'
21:32:30 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWRinfo' from client '1': server error
21:32:30 T:2882534208 ERROR: EPG - Update - failed to update table 'SWRinfo'
21:32:30 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'TF1 HD' from client '1': server error
21:32:30 T:2882534208 ERROR: EPG - Update - failed to update table 'TF1 HD'
21:32:30 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'France 2 HD' from client '1': server error
21:32:30 T:2882534208 ERROR: EPG - Update - failed to update table 'France 2 HD'
21:32:31 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:31 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:31 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'M6 HD' from client '1': server error
21:32:31 T:2882534208 ERROR: EPG - Update - failed to update table 'M6 HD'
21:32:31 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'TF6' from client '1': server error
21:32:31 T:2882534208 ERROR: EPG - Update - failed to update table 'TF6'
21:32:31 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'Bel RTL' from client '1': server error
21:32:31 T:2882534208 ERROR: EPG - Update - failed to update table 'Bel RTL'
21:32:32 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:32 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:32 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'CANAL+ HD' from client '1': server error
21:32:32 T:2882534208 ERROR: EPG - Update - failed to update table 'CANAL+ HD'
21:32:32 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel '<n/a>' from client '1': server error
21:32:32 T:2882534208 ERROR: EPG - Update - failed to update table '<n/a>'
21:32:32 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SPORT 365' from client '1': server error
21:32:32 T:2882534208 ERROR: EPG - Update - failed to update table 'SPORT 365'
21:32:32 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:32:32 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'ACTION' from client '1': server error
21:32:32 T:2882534208 ERROR: EPG - Update - failed to update table 'ACTION'
21:32:33 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:33 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:33 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'CARTOON NETWORK' from client '1': server error
21:32:33 T:2882534208 ERROR: EPG - Update - failed to update table 'CARTOON NETWORK'
21:32:33 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'DISNEY JUNIOR' from client '1': server error
21:32:33 T:2882534208 ERROR: EPG - Update - failed to update table 'DISNEY JUNIOR'
21:32:33 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:32:33 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'DISNEY JUNIOR HD' from client '1': server error
21:32:33 T:2882534208 ERROR: EPG - Update - failed to update table 'DISNEY JUNIOR HD'
21:32:34 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:34 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:34 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'JUNE' from client '1': server error
21:32:34 T:2882534208 ERROR: EPG - Update - failed to update table 'JUNE'
21:32:34 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:32:34 T:2749745984 NOTICE: Thread FileCache start, auto delete: false
21:32:34 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'PIWI+' from client '1': server error
21:32:34 T:2882534208 ERROR: EPG - Update - failed to update table 'PIWI+'
21:32:34 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC BLACK' from client '1': server error
21:32:34 T:2882534208 ERROR: EPG - Update - failed to update table 'M6 MUSIC BLACK'
21:32:35 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:32:35 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:32:35 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'MTV Music 24' from client '1': server error
21:32:35 T:2882534208 ERROR: EPG - Update - failed to update table 'MTV Music 24'
21:32:35 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'MELODIE TV' from client '1': server error
21:32:35 T:2882534208 ERROR: EPG - Update - failed to update table 'MELODIE TV'
21:32:35 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'HISTOIRE' from client '1': server error
21:32:35 T:2882534208 ERROR: EPG - Update - failed to update table 'HISTOIRE'
21:32:35 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'PLANETE+ CI' from client '1': server error
21:32:35 T:2882534208 ERROR: EPG - Update - failed to update table 'PLANETE+ CI'
21:32:36 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:33:02 T:2773224256 NOTICE: Previous line repeats 7 times.
21:33:02 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:33:40 T:2773224256 NOTICE: Previous line repeats 1 times.
21:33:40 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:07 T:2773224256 NOTICE: Previous line repeats 3 times.
21:35:07 T:2773224256 NOTICE: Thread FileCache start, auto delete: false
21:35:11 T:2823879488 NOTICE: Previous line repeats 1 times.
21:35:11 T:2823879488 NOTICE: ES: Client XBMC Constellation from 192.168.1.24 timed out
21:35:27 T:2707417920 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:27 T:2682256192 NOTICE: Thread JobWorker start, auto delete: true
21:35:32 T:2707417920 NOTICE: Previous line repeats 1 times.
21:35:32 T:2707417920 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:32 T:2707417920 NOTICE: -->Python Interpreter Initialized<--
21:35:32 T:2707417920 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:32 T:2707417920 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:32 T:2707417920 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:32 T:2707417920 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:35:32 T:2673863488 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:32 T:2707417920 NOTICE: Thread JobWorker start, auto delete: true
21:35:37 T:2673863488 NOTICE: Previous line repeats 1 times.
21:35:37 T:2673863488 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:37 T:2673863488 NOTICE: -->Python Interpreter Initialized<--
21:35:37 T:2673863488 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:37 T:2673863488 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:37 T:2673863488 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:38 T:2673863488 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:35:38 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:42 T:2752510784 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:42 T:2752510784 NOTICE: -->Python Interpreter Initialized<--
21:35:42 T:2752510784 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:42 T:2752510784 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:42 T:2752510784 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:43 T:2752510784 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:35:43 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:46 T:2752510784 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:46 T:2752510784 NOTICE: -->Python Interpreter Initialized<--
21:35:46 T:2752510784 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:46 T:2752510784 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:46 T:2752510784 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:47 T:2752510784 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:35:48 T:3063105280 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for https://r6---sn-cxab5jvh-cg0s.googlevide...424FF6B08E
21:35:48 T:3063105280 NOTICE: DVDPlayer: Opening: https://r6---sn-cxab5jvh-cg0s.googlevide...424FF6B08E
21:35:48 T:3063105280 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:35:48 T:2752510784 NOTICE: Thread DVDPlayer start, auto delete: false
21:35:48 T:2752510784 NOTICE: Creating InputStream
21:35:48 T:2752510784 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
21:35:48 T:2752510784 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
21:35:48 T:2752510784 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:35:48 T:2752510784 ERROR: Open - failed to open source <https://r6---sn-cxab5jvh-cg0s.googlevideo.com/videoplayback?key=yt5&ip=81.247.6.232&itag=22&mm=31&ms=au&ipbits=0&pl=21&mv=m&mt=1421354097&expire=1421375747&upn=2V5GyPc4w2U&mime=video/mp4&sparams=dur,gcr,id,initcwndbps,ip,ipbits,itag,mime,mm,ms,mv,pl,ratebypass,requiressl,source,upn,expire&gcr=be&requiressl=yes&ratebypass=yes&id=o-ACTKJmaPtKa7FTl1AgpVpC-YBq66jygKVMkdxm9xVu75&fexp=900228,900718,907263,916608,924622,927622,9406034,940925,941004,942704,943917,947209,947225,948124,952302,952605,952901,955301,957103,957105,957201,959701&sver=3&initcwndbps=1077500&dur=198.251&source=youtube&signature=69669691D8A8623F75996E325DA4248CFD79E18F506AC.C067BEE2659E957794EF910AE9C97B424FF6B08E>
21:35:48 T:2752510784 ERROR: CDVDPlayer::OpenInputStream - error opening [https://r6---sn-cxab5jvh-cg0s.googlevide...424FF6B08E]
21:35:48 T:2752510784 NOTICE: CDVDPlayer::OnExit()
21:35:48 T:2752510784 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:35:48 T:3063105280 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=cmE_aahc448]
21:35:48 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:48 T:3063105280 NOTICE: CDVDPlayer::CloseFile()
21:35:48 T:3063105280 NOTICE: DVDPlayer: waiting for threads to exit
21:35:48 T:3063105280 NOTICE: DVDPlayer: finished waiting
21:35:48 T:2673863488 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:48 T:2673863488 NOTICE: -->Python Interpreter Initialized<--
21:35:48 T:2673863488 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:48 T:2673863488 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:48 T:2673863488 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:49 T:2673863488 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:35:51 T:2673863488 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:51 T:2673863488 NOTICE: -->Python Interpreter Initialized<--
21:35:52 T:2673863488 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:52 T:2673863488 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:52 T:2673863488 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:52 T:2673863488 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:35:53 T:3063105280 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for https://r7---sn-cxab5jvh-cg0e.googlevide...AD9C6EE28D
21:35:53 T:3063105280 NOTICE: DVDPlayer: Opening: https://r7---sn-cxab5jvh-cg0e.googlevide...AD9C6EE28D
21:35:53 T:3063105280 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:35:53 T:2673863488 NOTICE: Thread DVDPlayer start, auto delete: false
21:35:53 T:2673863488 NOTICE: Creating InputStream
21:35:53 T:2673863488 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
21:35:53 T:2673863488 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
21:35:53 T:2673863488 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:35:53 T:2673863488 ERROR: Open - failed to open source <https://r7---sn-cxab5jvh-cg0e.googlevideo.com/videoplayback?id=o-ANhOM_hq8p7ZOPUIw6n3lOETFKvS2RLOgI1tyq6e_Wr4&ipbits=0&key=yt5&mime=video/mp4&expire=1421375752&gcr=be&sver=3&mt=1421354097&ip=81.247.6.232&itag=22&fexp=900718,907263,924630,924638,924808,927622,940000,9406131,941004,943917,947209,947225,948124,952302,952605,952901,955301,957103,957105,957201,957401,959701&sparams=dur,gcr,id,initcwndbps,ip,ipbits,itag,mime,mm,ms,mv,pl,ratebypass,requiressl,source,upn,expire&pl=21&initcwndbps=1077500&dur=233.778&ms=au&mv=m&source=youtube&ratebypass=yes&requiressl=yes&mm=31&upn=92ZgZzHjiOo&signature=A94A949D25790EF9BD554A4129C5A98F0130E56F7E53F.78793902E723636E248D3C5D223706AD9C6EE28D>
21:35:53 T:2673863488 ERROR: CDVDPlayer::OpenInputStream - error opening [https://r7---sn-cxab5jvh-cg0e.googlevide...AD9C6EE28D]
21:35:53 T:2673863488 NOTICE: CDVDPlayer::OnExit()
21:35:53 T:2673863488 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:35:53 T:3063105280 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=j4-Gt6dUVj0]
21:35:53 T:2673863488 NOTICE: Thread BackgroundLoader start, auto delete: false
21:35:53 T:3063105280 NOTICE: CDVDPlayer::CloseFile()
21:35:53 T:3063105280 NOTICE: DVDPlayer: waiting for threads to exit
21:35:53 T:3063105280 NOTICE: DVDPlayer: finished waiting
21:35:53 T:2752510784 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:53 T:2752510784 NOTICE: -->Python Interpreter Initialized<--
21:35:54 T:2752510784 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
21:35:54 T:2752510784 NOTICE: [plugin.video.youtube] System: Gotham (2.14)
21:35:54 T:2752510784 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.4~beta6)
21:35:54 T:2752510784 NOTICE: [plugin.video.youtube] Shutdown of Kodion
21:36:23 T:2707417920 NOTICE: Thread JobWorker start, auto delete: true
21:37:13 T:2707417920 NOTICE: Thread FileCache start, auto delete: false
21:37:36 T:2882534208 NOTICE: Previous line repeats 2 times.
21:37:36 T:2882534208 ERROR: PVR - GetEPGForChannel - addon 'dm800:192.168.1.102' returned an error: server error
21:37:36 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'sunshine live' from client '1': server error
21:37:36 T:2882534208 ERROR: EPG - Update - failed to update table 'sunshine live'
21:37:36 T:2707417920 NOTICE: Thread FileCache start, auto delete: false
21:37:36 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR1 BW' from client '1': server error
21:37:36 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR1 BW'
21:37:36 T:2882534208 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SWR1 RP' from client '1': server error
21:37:36 T:2882534208 ERROR: EPG - Update - failed to update table 'SWR1 RP'
21:37:37 T:2707417920 NOTICE: Thread FileCache start, auto delete: false
21:43:29 T:2707417920 NOTICE: Thread FileCache start, auto delete: false
21:43:33 T:2707417920 NOTICE: Previous line repeats 1 times.
21:43:33 T:2707417920 NOTICE: Thread JobWorker start, auto delete: true
21:43:33 T:2635500352 NOTICE: Thread LanguageInvoker start, auto delete: false
21:43:33 T:2790009664 NOTICE: Thread JobWorker start, auto delete: true
21:43:33 T:2635500352 NOTICE: -->Python Interpreter Initialized<--
21:43:37 T:2635500352 NOTICE: Thread BackgroundLoader start, auto delete: false
21:43:37 T:2635500352 NOTICE: Thread JobWorker start, auto delete: true
21:43:41 T:2773224256 NOTICE: Previous line repeats 1 times.
21:43:41 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:43:49 T:2635500352 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
21:44:32 T:2627107648 NOTICE: Thread FileCache start, auto delete: false
21:44:37 T:2627107648 NOTICE: Previous line repeats 2 times.
21:44:37 T:2627107648 NOTICE: Thread BackgroundLoader start, auto delete: false
21:44:44 T:2627107648 NOTICE: Previous line repeats 1 times.
21:44:44 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:44:44 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:44:44 T:2627107648 NOTICE: (None, None)
21:44:44 T:2627107648 NOTICE: Mode: None
21:44:44 T:2627107648 NOTICE: Parameters: {'content_type': 'video'}
21:44:44 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:44:51 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:44:51 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:44:51 T:2627107648 NOTICE: (None, None)
21:44:52 T:2627107648 NOTICE: Mode: rootPlaylists
21:44:52 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/featured/staffpicks.json', 'mode': 'rootPlaylists', 'page': '1'}
21:44:52 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:44:53 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:44:53 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:44:54 T:2627107648 NOTICE: (None, None)
21:44:54 T:2627107648 NOTICE: Mode: listPlaylists
21:44:54 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/featured/staffpicks.json', 'mode': 'listPlaylists', 'page': '1'}
21:44:54 T:2627107648 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/featured/staffpicks.json
21:44:55 T:2627107648 NOTICE: Error reason:
21:44:55 T:2627107648 NOTICE: HTTP Error 500: Internal Server Error
21:44:55 T:2627107648 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: object of type 'bool' has no len()
File "/storage/.xbmc/addons/plugin.video.vevo/default.py", line 1562, in <module>
exec '%s()' % mode
File "<string>", line 1, in <module>
File "/storage/.xbmc/addons/plugin.video.vevo/default.py", line 593, in listPlaylists
playlists = demjson.decode(data)['result']
File "/storage/.xbmc/addons/plugin.video.vevo/demjson.py", line 2058, in decode
unitxt = auto_unicode_decode( txt )
File "/storage/.xbmc/addons/plugin.video.vevo/demjson.py", line 628, in auto_unicode_decode
if len(s) < 4:
TypeError: object of type 'bool' has no len()
21:44:55 T:3063105280 ERROR: GetDirectory - Error getting plugin://plugin.video.vevo/?mode=listPlaylists&page=1&url=http%3a%2f%2fapi.vevo.com%2fmobile%2fv1%2ffeatured%2fstaffpicks.json
21:44:55 T:3063105280 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vevo/?mode=listPlaylists&page=1&url=http%3a%2f%2fapi.vevo.com%2fmobile%2fv1%2ffeatured%2fstaffpicks.json) failed
21:44:55 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:44:55 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:44:55 T:2627107648 NOTICE: (None, None)
21:44:55 T:2627107648 NOTICE: Mode: rootPlaylists
21:44:55 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/featured/staffpicks.json', 'mode': 'rootPlaylists', 'page': '1'}
21:44:55 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:44:57 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:44:57 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:44:57 T:2627107648 NOTICE: (None, None)
21:44:57 T:2627107648 NOTICE: Mode: None
21:44:57 T:2627107648 NOTICE: Parameters: {'content_type': 'video'}
21:44:57 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:44:59 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:44:59 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:44:59 T:2627107648 NOTICE: (None, None)
21:44:59 T:2627107648 NOTICE: Mode: searchArtists
21:44:59 T:2627107648 NOTICE: Parameters: {'mode': 'searchArtists', 'page': '1'}
21:45:15 T:2627107648 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/search/art...=0&max=100
21:45:16 T:2752510784 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:24 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:24 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:25 T:2627107648 NOTICE: (None, None)
21:45:25 T:2627107648 NOTICE: Mode: None
21:45:25 T:2627107648 NOTICE: Parameters: {'content_type': 'video'}
21:45:25 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:26 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:26 T:2790009664 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://img.cache.vevo.com/Content/VevoIm...6A84E8.jpg
21:45:26 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:26 T:2635500352 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://img.cache.vevo.com/Content/VevoIm...594A00.jpg
21:45:26 T:2682256192 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://img.cache.vevo.com/Content/VevoIm...5761BD.jpg
21:45:26 T:2627107648 NOTICE: (None, None)
21:45:26 T:2627107648 NOTICE: Mode: searchArtists
21:45:26 T:2627107648 NOTICE: Parameters: {'mode': 'searchArtists', 'page': '1'}
21:45:32 T:2627107648 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/search/art...=0&max=100
21:45:33 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:34 T:2627107648 NOTICE: Thread FileCache start, auto delete: false
21:45:36 T:2627107648 NOTICE: Previous line repeats 1 times.
21:45:36 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:36 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:36 T:2627107648 NOTICE: (None, None)
21:45:36 T:2627107648 NOTICE: Mode: None
21:45:36 T:2627107648 NOTICE: Parameters: {'content_type': 'video'}
21:45:36 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:43 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:43 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:43 T:2627107648 NOTICE: (None, None)
21:45:43 T:2627107648 NOTICE: Mode: rootArtists
21:45:43 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/artist/list.json', 'mode': 'rootArtists', 'page': '1'}
21:45:43 T:2627107648 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/genre/list...ture=en_US
21:45:43 T:2707417920 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://img.cache.vevo.com/Content/VevoIm...331747.jpg
21:45:43 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:47 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:47 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:47 T:2627107648 NOTICE: (None, None)
21:45:47 T:2627107648 NOTICE: Mode: sortByArtists
21:45:47 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/artist/list.json?genres=pop', 'mode': 'sortByArtists', 'page': '1'}
21:45:47 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:49 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:49 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:49 T:2627107648 NOTICE: (None, None)
21:45:49 T:2627107648 NOTICE: Mode: sortWhenArtists
21:45:49 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/artist/list.json?genres=pop&order=MostViewed', 'mode': 'sortWhenArtists', 'page': '1'}
21:45:49 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:50 T:2627107648 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:50 T:2627107648 NOTICE: -->Python Interpreter Initialized<--
21:45:50 T:2627107648 NOTICE: (None, None)
21:45:50 T:2627107648 NOTICE: Mode: listArtists
21:45:50 T:2627107648 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/artist/list.json?genres=pop&order=MostViewedToday', 'mode': 'listArtists', 'page': '1'}
21:45:50 T:2627107648 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/artist/lis...=0&max=100
21:45:53 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:45:58 T:2773224256 NOTICE: Thread LanguageInvoker start, auto delete: false
21:45:58 T:2773224256 NOTICE: -->Python Interpreter Initialized<--
21:45:58 T:2773224256 NOTICE: (None, None)
21:45:58 T:2773224256 NOTICE: Mode: listArtistVideos
21:45:58 T:2773224256 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/artist/75f426ad-5e04-4f83-9dd5-88a9ca841201/videos.json?order=MostRecent', 'mode': 'listArtistVideos', 'page': '1'}
21:45:58 T:2773224256 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/artist/75f...ended=true
21:46:28 T:2773224256 NOTICE: Error reason:
21:46:28 T:2773224256 NOTICE: HTTP Error 500: Internal Server Error
21:46:28 T:3063105280 ERROR: GetDirectory - Error getting plugin://plugin.video.vevo/?mode=listArtistVideos&page=1&url=http%3a%2f%2fapi.vevo.com%2fmobile%2fv1%2fartist%2f75f426ad-5e04-4f83-9dd5-88a9ca841201%2fvideos.json%3forder%3dMostRecent
21:46:28 T:3063105280 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vevo/?mode=listArtistVideos&page=1&url=http%3a%2f%2fapi.vevo.com%2fmobile%2fv1%2fartist%2f75f426ad-5e04-4f83-9dd5-88a9ca841201%2fvideos.json%3forder%3dMostRecent) failed
21:46:28 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:46:48 T:2773224256 NOTICE: Thread LanguageInvoker start, auto delete: false
21:46:48 T:2773224256 NOTICE: -->Python Interpreter Initialized<--
21:46:49 T:2773224256 NOTICE: (None, None)
21:46:49 T:2773224256 NOTICE: Mode: listArtistVideos
21:46:49 T:2773224256 NOTICE: Parameters: {'url': 'http://api.vevo.com/mobile/v1/artist/75f426ad-5e04-4f83-9dd5-88a9ca841201/videos.json?order=MostRecent', 'mode': 'listArtistVideos', 'page': '1'}
21:46:49 T:2773224256 NOTICE: VEVO --> common :: getURL :: url = http://api.vevo.com/mobile/v1/artist/75f...ended=true
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:18' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:34' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:58' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '7:52' as 7 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '2:40' as 2 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '9:19' as 9 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:20' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:52' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:40' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '6:3' as 6 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:50' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:29' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:25' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '6:16' as 6 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:27' as 4 minutes
21:46:55 T:2773224256 WARNING: Previous line repeats 1 times.
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:11' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:46' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:21' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '8:0' as 8 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:49' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:35' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:44' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0:0' as 0 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:11' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '5:59' as 5 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:56' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '22:30' as 22 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:53' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:42' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:9' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:29' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0:20' as 0 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0:44' as 0 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0:28' as 0 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0:23' as 0 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '20:44' as 20 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '8:11' as 8 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '2:3' as 2 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '6:17' as 6 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '2:26' as 2 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '2:24' as 2 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:28' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:0' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:35' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:13' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:12' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:10' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:2' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '8:14' as 8 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '5:16' as 5 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '5:3' as 5 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:36' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '5:22' as 5 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:47' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '7:18' as 7 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '21:1' as 21 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '1:18' as 1 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0:42' as 0 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:57' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:39' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:23' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '5:20' as 5 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:47' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:49' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:48' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:19' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:1' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:45' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '4:0' as 4 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:37' as 3 minutes
21:46:55 T:2773224256 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '3:18' as 3 minutes
21:46:55 T:2773224256 NOTICE: Thread BackgroundLoader start, auto delete: false
21:47:12 T:2682256192 NOTICE: Thread JobWorker start, auto delete: true
21:47:22 T:2773224256 NOTICE: Previous line repeats 1 times.
21:47:22 T:2773224256 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://img.cache.vevo.com/Content/VevoIm...330968.png
21:47:24 T:2707417920 NOTICE: Thread LanguageInvoker start, auto delete: false
21:47:24 T:2707417920 NOTICE: -->Python Interpreter Initialized<--
21:47:24 T:2707417920 NOTICE: (None, None)
21:47:24 T:2707417920 NOTICE: Mode: playVideo
21:47:24 T:2707417920 NOTICE: Parameters: {'url': 'TIVEV1460907', 'duration': '118', 'mode': 'playVideo'}
21:47:24 T:2707417920 NOTICE: VEVO --> common :: getURL :: url = http://videoplayer.vevo.com/VideoService...VEV1460907
21:47:26 T:2707417920 NOTICE: VEVO --> common :: getURL :: url = http://videoplayer.vevo.com/VideoService...VEV1460907
21:47:26 T:2707417920 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: 'NoneType' object has no attribute '__getitem__'
exec '%s()' % mode
File "/storage/.xbmc/addons/plugin.video.vevo/default.py", line 934, in playVideo
playlistVideo()
File "/storage/.xbmc/addons/plugin.video.vevo/default.py", line 957, in playlistVideo
except:YouTube()
File "/storage/.xbmc/addons/plugin.video.vevo/default.py", line 1302, in YouTube
youtubeID = demjson.decode(data)['video']['videoVersions'][0]['id']
TypeError: 'NoneType' object has no attribute '__getitem__'
21:47:26 T:3063105280 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.vevo/?url=TIVEV1460907&mode=playVideo&duration=118]
21:47:29 T:2707417920 NOTICE: Thread BackgroundLoader start, auto delete: false
21:47:30 T:2707417920 NOTICE: Thread LanguageInvoker start, auto delete: false
21:47:30 T:2707417920 NOTICE: -->Python Interpreter Initialized<--
21:47:40 T:2707417920 NOTICE: Thread FileCache start, auto delete: false
21:47:52 T:2882534208 NOTICE: Previous line repeats 2 times.
TLDNR
(2015-01-15, 23:39)dkplayaclub Wrote: [ -> ]TLDNR
Indeed Wink
