(2015-03-02, 15:28)bromix Wrote: [ -> ]This I have to test...in the browser it's working for me...I look into it...and please update your addon to v5.0.7
After updating to v5.08 beta2 it's working again.
(2015-03-03, 20:27)bromix Wrote: [ -> ] (2015-03-01, 14:28)TheDefiant604 Wrote: [ -> ]Is it possible to add the ability to update the watched videos history? I'd like to have this included in the add-on so that I can quickly find videos I watched in Kodi when I'm browsing YouTube directly.
Okay...found the bug... I use the call of YouTube TV for updating the History...it isn't working for YouTube TV and therefore also not for the addon. I hope they will fix this...because here is nothing a can do
Thank you for the info. It's a shame this one instance doesn't work.
After 5.0.8~beta2 update, The addon refreshes periodically and automatically resets to Media info 2 view no matter how many times I set it to another view. After the update it made me redo settup/login process again but that's not a biggie like the layout and constant refresh.
(2015-03-04, 03:14)snafu21 Wrote: [ -> ]After 5.0.8~beta2 update, The addon refreshes periodically and automatically resets to Media info 2 view no matter how many times I set it to another view. After the update it made me redo settup/login process again but that's not a biggie like the layout and constant refresh.
Sounds like you have some old data or addon flying around. Do you used the YouTube forwarder or the patched YouTube of learninggit? This addons have all higher version numbers and can maybe conflict with the mechanism of XBMC/KODI. Try to sort out old YouTube addons in your addon folder or do a fresh install.
(2015-03-02, 17:44)jonib Wrote: [ -> ] (2015-03-02, 09:25)xbmcwayist Wrote: [ -> ]Oh, and what about on Gotham? Can I just remove the old YouTube addon and the forwarder and everything will work with Bromix's YouTube?
I think it's best to remove both Youtube addons and the forwarder, then from the Bromix repository install the latest addon.
jonib
Thanks, that is what I did and it all seems to work just fine on both Helix and Gotham.
(2015-03-02, 17:49)bromix Wrote: [ -> ]For now I support the old calls/urls of the other addon, so older addons which require YouTube will work. But starting with KODI 15.X I will start to drop this support, because the old url-calls are a pain. URIs are so much powerfull, but the old calling-conventions doesn't make any use of it
Ah, I see. Well now that your YouTube addon is the official one, other addons will update their URIs accordingly.
Installed a fresh OpenELEC 5.0.5.
Booted up and installed Youtube Plugin right away.
Logged in.
No video playback possible.
Not even one video I tried worked ....
Notfication in the corner say something about a "Script error" see log for details.
Log:
http://pastebin.com/NSLfp8fa
Can somebody help me to fix my problem?
(2015-03-05, 22:19)hansinger Wrote: [ -> ]Installed a fresh OpenELEC 5.0.5.
Logged in.
Log:
Working fine for me...but can you switch to debug...I need more infos in the log....I suspect another OE without HTTPs support.
(2015-03-05, 22:26)bromix Wrote: [ -> ] (2015-03-05, 22:19)hansinger Wrote: [ -> ]Installed a fresh OpenELEC 5.0.5.
Logged in.
Log:
what do I have to do, to get you a proper log?
/e: found it. getting you a debug log right now
Logged in.
Log:
I get script error when there is no internet connection. Check your internet configuration make sure it is working.
thanks, but if there would be no internet connection:
- I would not have been able to load the youtube plugin
- the newsticker on the main menu would not work
- the youtube video search would not work
- the small thumbnails of the videos would not load.
But all these things DO load.
Therefore an internet connection is established (imho)
(2015-03-05, 22:57)hansinger Wrote: [ -> ]Debug Log:
(Started OpenELEC, went into the youtube addon and tried to play 5 different videos)
http://pastebin.com/j29XFG6D
Mhmmm...I can't see anything strange now only this:
20:51:46 T:140014215735168 NOTICE: WARNING: unsupported ffmpeg version detected
But this is not the problem. I have to take a look tomorrow and improve some error handling....for some reason you aren't getting any information for any video.
Thanks,
the file I downloaded is this one:
[Stable] OpenELEC 5.0.5 (x86_64) Diskimage
directly from:
http://openelec.tv/get-openelec
If I can gice you more infos, I'm glad to assist.
Received an automatic Update of the Youtube Addon and now the issue is fixed.
I guess you sorted it out?!
