I just installed on my FireTV stick. I've only used it for a short time, but so far, so great!
It loads up in a heartbeat, and plays movie videos just fine.
I compared it to the "official" app for the Fire stick, and there's no contest. This app wins by a landslide!
Highly recommended!
Thank you for a terrific add-on, bromix.
(2015-03-08, 15:11)Uukrul Wrote: [ -> ]There is a little problem with the addon and current Kodi master builds (15.0-ALPHA2). With Kodi 14.x there is no such problems.
Runtime isn't correct:
Thanks in advance.
(2015-03-08, 20:30)Martijn Wrote: [ -> ]...
https://github.com/xbmc/xbmc/pull/5562
Starting with
v5.0.9 this addon will support both ways
Great! Now I can "un-revert" that PR.
(2015-03-09, 18:39)bromix Wrote: [ -> ] (2015-03-09, 05:35)superryo Wrote: [ -> ]Alibaba - do you know if there is an equivalent to show content of the playlist and not play it?
A clean Endpoint for that is missing but I can add this Endpoint for v5.0.9.
What could work is the following:
plugin://plugin.video.youtube/channel/NOTHING/playlist/<PLAYLIST_ID>/
Unfortunately the playlist functionality doesn't work.
(2015-03-09, 03:23)superryo Wrote: [ -> ] (2015-03-09, 02:42)superryo Wrote: [ -> ] (2015-03-09, 02:22)superryo Wrote: [ -> ]Hey Bromix. I did follow those instructions and everything was working beautifully. However today for some reason when i tried, the login keeps saying it can't login. I am able to login vis my computer browser so I guess i am saying something is corrupted on my Android box. I just can't seem to force a login or logout to fix the problem.
Bromix - here are my logs: http://pastebin.com/J6ty87fe
It doesn't seem to say anything I can figure out. When I run the app, it just errors out and tells me unable to login and backs out.
Hi Bromix - any ideas?
Just a bit more background. on a windows desktop browser, I am able to login. On an iphone app I am able to login. On an android tablet I am able to login. However on an iphone mobile browser, I get an error that says "oops something went wrong..." The only way I can prevent this error was to use
https://m.youtube.com and it works. Now on the Android TV box, I just get the "Login failed" error.
Hello
This is the correct line
PlayMedia("plugin://plugin.video.youtube/play/?video_id=_maBGM-i8OQ"
And this I am trying to do, of course without success.
PlayMedia("plugin://plugin.video.youtube/play/?video_id=_$INFO[Skin.String(GamesName)]"
If someone has a suggestion, I would be grateful.
(2015-03-14, 08:35)superryo Wrote: [ -> ] (2015-03-09, 18:39)bromix Wrote: [ -> ] (2015-03-09, 05:35)superryo Wrote: [ -> ]Alibaba - do you know if there is an equivalent to show content of the playlist and not play it?
You're probably working with 5.0.8 but a
debuf log (wiki) would already told us that. This Endpoint ist available with 5.0.9
(2015-03-14, 08:38)superryo Wrote: [ -> ] (2015-03-09, 03:23)superryo Wrote: [ -> ] (2015-03-09, 02:42)superryo Wrote: [ -> ]
Just a bit more background. on a windows desktop browser, I am able to login. On an iphone app I am able to login. On an android tablet I am able to login. However on an iphone mobile browser, I get an error that says "oops something went wrong..." The only way I can prevent this error was to use https://m.youtube.com and it works. Now on the Android TV box, I just get the "Login failed" error.
Just use the Windows browser again
you don't have to use the browser on the device. This is a routine YouTube uses for TVs and they haven't any browser (some of them).
(2015-03-14, 11:19)senna99 Wrote: [ -> ]....
I apologize for this error,I did not know I need to hang debug log.
http://goo.gl/sLeqnZ
No harm done
but based on the log I can see, that you're calling the addon with the following parameter:
"plugin://plugin.video.youtube/play/?video_id=_Pro Evolution Soccer 2012"
This isn't correct
(2015-03-14, 14:31)bromix Wrote: [ -> ] (2015-03-14, 11:19)senna99 Wrote: [ -> ]....
No harm done but based on the log I can see, that you're calling the addon with the following parameter:
This isn't correct
Thanks for the reply
But what this means, I make a mistake with $INFO[Skin.String(GamesName)] or this is not possible.
For example, this line works perfectly
Quote: <content limit="10">plugin://plugin.video.youtube/kodion/search/query/?q=$INFO[Skin.String(GamesName)]"</content>
Best Regards
You need an ID
For example this video:
https://www.youtube.com/watch?v=sSdPoDMdQhI
the ID is
sSdPoDMdQhI
What you provided was the title of the video.
The other thing that works for you is a search
no wonder it's working
(2015-03-14, 19:35)bromix Wrote: [ -> ]You need an ID
the ID is sSdPoDMdQhI
The other thing that works for you is a search no wonder it's working
Ok thanks for answers, I will not ask more questions about this.
Now I will check a new version of youtube.
Best Regards
