Full Version: screen size
hi hope some can help when I turn on my box its ok till I scroll onto the xbmc part then when I click on that the screen goes to a third off the screen how to I get it back to full size thanks
Quote:scroll onto the xbmc part
What does that mean?
Are you running XBMC in windowed mode? If so you need to change to fullscreen from the settings. A bit more information about your setup would also be nice, read the forum rules.
Hi I've had the box 6 months was watching something turned it off when I turned it back on it went to small screen but only on the xbmc part everything else is is ok
That was totally not helpful in any way. Did you read any of what I just wrote?
press the backslash key "\"
