Hello
Not sure if this is the right place to post, so please move if necessary.
For some reason I am now getting an error message when ever I look at info on tv shows or movies. It is an Extended Info error. I posted my log and the question on the skin forum thinking it was an error with the skin. However I got the following reply:
Quote:It's saying you're missing the downloader.external module, no idea so suggest posting a link to your log in the ExtendedInfo thread. You can also try manually installing the latest ExtendedInfo version from the Jarvis branch on github, which is available at the following link:
https://github.com/phil65/script.extende...jarvis.zip
Here is the link to my log file Your debug kodi.log:
http://xbmclogs.com/pof3tfcer
Many thanks. Eon
the error comes from the youtube downloader script. i've moved your post there.
(2016-04-08, 10:46)eondesigns1138 Wrote: [ -> ]Hello
Here is the link to my log file Your debug kodi.log: http://xbmclogs.com/pof3tfcer
Many thanks. Eon
The log link is not working - perhaps expired. If you get a new one I'll look at it.
Sent from my SM-N910P
I get errors with X when I want to have information about a video.
11:45:44 62.065296 T:1671427056 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named downloader.external
File "/home/osmc/.kodi/addons/script.extendedinfo/plugin.py", line 10, in <module>
from resources.lib.process import start_info_actions
File "/home/osmc/.kodi/addons/script.extendedinfo/resources/lib/process.py", line 17, in <module>
import VideoPlayer
File "/home/osmc/.kodi/addons/script.extendedinfo/resources/lib/VideoPlayer.py", line 10, in <module>
import YDStreamExtractor
File "/home/osmc/.kodi/addons/script.module.youtube.dl/lib/YDStreamExtractor.py", line 8, in <module>
import YoutubeDLWrapper
File "/home/osmc/.kodi/addons/script.module.youtube.dl/lib/YoutubeDLWrapper.py", line 11, in <module>
from youtube_dl.utils import std_headers, DownloadError #analysis:ignore
File "/home/osmc/.kodi/addons/script.module.youtube.dl/lib/youtube_dl/__init__.py", line 15, in <module>
from .options import (
File "/home/osmc/.kodi/addons/script.module.youtube.dl/lib/youtube_dl/options.py", line 7, in <module>
from .downloader.external import list_external_downloaders
ImportError: No module named downloader.external
11:45:44 62.309658 T:1496314864 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=traktsimilartvshows&&dbid=186
http://pastebin.com/cH6is5FB
Thx !
(2016-05-20, 22:27)Konradovitsch Wrote: [ -> ]I am trying this with youtube-dl --get-url and i am getting my stream link!
if i am trying it with this api i am getting an None Object but only if am wanting to get a streaming url for Streamcloud.eu
vid = YDStreamExtractor.getVideoInfo(streamLink,2,True)
=> vid is None
root@********:/var/www/html/api/sc# youtube-dl --get-url http://streamcloud.eu/123467343462453452...D.mkv.html
http://cdn5.streamcloud.eu:8080/zhv75l3i.../video.mp4
It is likely the version installed on your system is newer than the one in the youtube-dl addon. I'll update to the latest - let me know if you still have the issue when you try it with that.
(2016-05-21, 10:45)Alyy Wrote: [ -> ]Hi,
import VideoPlayer
Thx !
There seems to be something wrong with your youtube-dl addon install. You're getting an error on import, which isn't happening to anyone else as far as I know. Try un-installing it and make sure that you install the addon via the repository or by using "Install from zip file". Also, your pastebin log doesn't contain the error or any usage of the addon, so there isn't much I can get from that.
Version 16.521.0
Changes:
- Updated youtube-dl core to 2016.05.21.2
On Kodi repo, pending mirror updates.
(2016-05-22, 17:49)ruuk Wrote: [ -> ] (2016-05-20, 22:27)Konradovitsch Wrote: [ -> ]I am trying this with youtube-dl --get-url and i am getting my stream link!
=> vid is None
import VideoPlayer
Thx !
I uninstall addon youtube-dl or youtube or bothe ?
I have youtube-dl 16.318.0 and youtube 5.1.20.4
(2016-05-22, 18:37)Alyy Wrote: [ -> ]I uninstall addon youtube-dl or youtube or bothe ?
Just the youtube-dl addon. The YouTube addon has nothing to do with youtube-dl.
(2016-05-22, 18:50)ruuk Wrote: [ -> ] (2016-05-22, 18:37)Alyy Wrote: [ -> ]I uninstall addon youtube-dl or youtube or bothe ?
By installing the latest version, this fixes the problem. the error occurred just one time,
I think it's good ?
20:46:33 7724.666992 T:1671951344 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: list indices must be integers, not str
File "/home/osmc/.kodi/addons/script.extendedinfo/plugin.py", line 103, in <module>
Main()
File "/home/osmc/.kodi/addons/script.extendedinfo/plugin.py", line 31, in __init__
listitems = start_info_actions(info, self.params)
File "/home/osmc/.kodi/addons/script.extendedinfo/resources/lib/process.py", line 163, in start_info_actions
movies = tmdb.get_person_movies(director_info["id"])
File "/home/osmc/.kodi/addons/script.extendedinfo/resources/lib/TheMovieDB.py", line 1192, in get_person_movies
return handle_movies(response["crew"])
File "/home/osmc/.kodi/addons/script.extendedinfo/resources/lib/TheMovieDB.py", line 318, in handle_movies
ids = [item["id"] for item in response["genres"]]
TypeError: list indices must be integers, not str
20:46:33 7725.143066 T:1652675568 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=directormovies&&director=Alejandro G. Iñárritu
I tried reinstalling th eaddon but it doesnt work with streamcloud.eu but it works on my root and it dont understand why it gives me a None feedback.
(2016-05-23, 19:19)Konradovitsch Wrote: [ -> ]I tried reinstalling the addon but it doesnt work with streamcloud.eu but it works on my root and it dont understand why it gives me a None feedback.
That's why I said I thought there was a version difference. None means no info, and is what you would get with an unsupported site or if the handler for a supported site failed to resolve the URL.
You said you re-installed, but are you sure you are on the new version - 16.521.0?
(2016-05-23, 19:52)ruuk Wrote: [ -> ] (2016-05-23, 19:19)Konradovitsch Wrote: [ -> ]I tried reinstalling the addon but it doesnt work with streamcloud.eu but it works on my root and it dont understand why it gives me a None feedback.
its
<addon id="script.module.youtube.dl" name="youtube-dl Control" version="16.327.0"
(2016-05-24, 20:54)Konradovitsch Wrote: [ -> ] (2016-05-23, 19:52)ruuk Wrote: [ -> ] (2016-05-23, 19:19)Konradovitsch Wrote: [ -> ]I tried reinstalling the addon but it doesnt work with streamcloud.eu but it works on my root and it dont understand why it gives me a None feedback.
its
Well, let me know if it still doesn't work when you are updated with the new version. You may need to force refresh/check for updates on the Kodi repo.
