Full Version: [Update 0.1.1 ] the ultimate source of adult movies
Pages: 1 2
Eek
Here it is the Dino Tube addon for KODI ! Cool
MAJOR UPDATE--- Addon 's Core Rewrited ----
Big collection of 100% Free Porn Tube movies,
Dino Tube.com, the #1 XXX tube videos site.
Daily updated content in every category that you can think of
This addon allowing to have acces to the dinotube server on kodi [Windows only]
Use this adult addon to acces to
the daily updated content of
more than 1080 videos porn categories
more than 100 differents videos porn servers
and possibilities to add infinitively new servers
and download any tube.
You can browse into the multiples differents porn categories and navigate into them by Popularity, Duration, Date, Rating, Votes, Search and save your favourites categories.
You can also navigate easely with " jump to page ".
You can make custom search with personnal request.
You can add infinitively new servers to be supported by the addon with a simple semi automatic process.
You can download any tube by one click on a contextual menu.
You can configure the dinotube addon for kodi with a lot of settings to adjust his comportment with your internet connection and your hardware configuration
This addon allow you to
browse categories
The Dinotube addon for Kodi allow you to browse in more than 1000 porn categories.
These represent one the biggest collection of videos porn.
You can browse in the categories by navigate by Popularity, Duration, Date, Rating, Votes, and search
get your own favourites categories
The Dinotube addon for Kodi allow you to save your favorites categories.
You save them into the favourites categories section of the addon
that make easier to browse directly in your preferred porn content.
custom search
The Dinotube addon for Kodi allow you to make some custom search in the all porn movies referenced on the dinotube server.
You can acces directly to all your specials requests
jump to page
The Dinotube addon for Kodi allow you to jump directly at a specific page of the result of your search or your categories browsing whether by popularity, duration, date, rating or votes, search.
In this way, your experience of navigation is made easier.
Add servers
The Dinotube addon for Kodi allow you to add new porn server who will be supported by the addon.
Indeed, you can add new porn server in a easy way by the semi automatic process by just positionning the pointer in the right place.
Download tube
The Dinotube addon for Kodi allow you to download the tube you want,.....by one click in the contextual menu of the video.
You can easely acces to the downloaded tube in the "downloaded tube" section of the addon.
be fully customizable
The Dinotube addon for Kodi allow you to have acces to a lot of settings enable to adjust the comportment of the addon to your internet connection and your hardware configuration,....
To have the best experience when using the Dinotube addon for Kodi
******************************install Modus Operandi******************************
the dependencies...
script.module.elementtree-1.2.8.zip
script.module.simple.downloader-1.9.4.zip
this version of script.module.parsedom_2.5.2.zip
Before use the addon
Update the FireFox Profil used by the addon
To make that
run firefox.exe with the argument "-p"
"C:\Program Files (x86)\Mozilla Firefox\firefox.exe" -p
in the dialog box choose ""create profil""
"choose a folder"
and browse to C:\Users\USER\AppData\Roaming\Kodi\addons\plugin.video.dino\resources\FireFoxProfile\tdpf2upa.default
and select ""tdpf2upa.default"" folder
make update for firefox addons with update activated
IMPORTANT
the browser bar of firefox with the profil ""tdpf2upa.default"" must be like this
because per example kaspersky or some internet suite can install complementary module
just customize the browser bar to looks like this
you must at least have a resolution of 1280-800
you must dont move the mouse during the addon's automation procedure
Implementation of ADD SERVER semi automatic process to add server supported by the addon...
Sever settings are provided with the addon but for the new one or modifed servers
You must easly ADD SERVER
when you launch a video
if the server is not present or if the server doesnt return a correct url
you can add server with a semi automatic process
click add or yes to modify
Wait the video page,.. after have seen a black popup window
oyu have 10 seconde to SET POSITION the cursor on the video page
WHERE the video must be launch,
dont move until you see again completly kodi window...it is done
the settings for this server are saved.
The nex time all will be made by the automation process
Since FireFox 41 Use This Version :
------------------------------------------------------------------------------ DINOTUBE FOR KODI --------------------------------------------------------------------------------------------------------------------
MAJOR UPDATE version 0.1.1 Dinotube for Kodi
rem: hope i can post this content in this section,....
(2014-07-29, 06:15)alamata Wrote: [ -> ]Eek
Here it is the Dino Tube addon for XBMC! Cool
This addon allow you to browse in the 1080 categories !!
of adult movies web present in the dinotube site ...
you can browse in the categories of your choice by popularity, duration or date of upload....
you can save your preferred cartegories into the favourites categories section of the addon
this addon allow you to make custom search in all the movies
this addon allow you to download the tube you want ... !!!
at this time this addon support 115 servers...!!
but this list can grow easily, it's totally open, and easy to make ...
the addon have some settings customizable depending of your internet connections
it take nearby 15 or more sec to have a video to watch depending of the setting and of your connection speed
the debug setting allow you to see the automation procedure of the addon
here some links for the dependance of the addon
https://anarchintosh-projects.googlecode...-1.2.7.zip
https://github.com/XBMC-Addons/script.mo...master.zip
http://ftp.heanet.ie/mirrors/xbmc/addons...-1.9.4.zip
ftp://ftp.gr.freebsd.org/pub/video/xbmc/...-2.5.1.zip
in some cases you must install
python 2.7 and pywin32-215
the best way to install the addon is to extract the zip into the apporriate folder
you must dont move the mouse during the addon's procedure
tested on win 8.1 and gotham 13.1
here it is in action,....
the link for the addon....
dinotube addon prerelease
your last link is broken .. I assume that means the whole post is useless.
http://ftp.ftp.gr.freebsd.org/pub/video/xbmc/addons/frodo/script.module.parsedom/script.module.parsedom-2.5.1.zip
(2014-07-30, 01:08)Hi8 Wrote: [ -> ]your last link is broken .. I assume that means the whole post is useless.
here is an other link,...
http://mirrors.xbmc.org/addons/frodo/scr...-2.5.2.zip
i hope not,... Wink
Dependencies not met error xbmc 13.2 beta 1
edit:
01:31:20 T:7096 NOTICE: ===============================
01:31:20 T:7096 NOTICE: DINOTUBE
01:31:20 T:6352 NOTICE: Previous line repeats 1 times.
01:31:20 T:6352 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.dinoxC/
01:31:20 T:6352 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.dinoxC/) failed
01:31:20 T:6408 NOTICE: Thread BackgroundLoader start, auto delete: false
01:31:33 T:3540 NOTICE: Previous line repeats 4 times.
01:31:33 T:3540 NOTICE: Thread LanguageInvoker start, auto delete: false
01:31:34 T:3540 NOTICE: -->Python Interpreter Initialized<--
01:32:03 T:4584 NOTICE: Thread JobWorker start, auto delete: true
01:32:03 T:4240 ERROR: dll_fgets emulated function failed
01:32:43 T:5908 NOTICE: Thread BackgroundLoader start, auto delete: false
01:33:06 T:6788 NOTICE: Previous line repeats 3 times.
01:33:06 T:6788 NOTICE: Thread LanguageInvoker start, auto delete: false
01:33:06 T:6788 NOTICE: -->Python Interpreter Initialized<--
01:33:07 T:6788 ERROR: EXCEPTION: Could not get AddonPtr given a script id of plugin.video.belgium.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a Version: 2.0 plugin.
01:33:07 T:6788 NOTICE: CommonFunctions-2.5.1
not yet with 13.2 Rolleyes
i wait a ""stable version""
there is surely a way to ""bypass"
even if i must modify the source,....Nod
(2014-07-30, 01:36)alamata Wrote: [ -> ]
I think it's a bug located at channel.py line 10
__settings__ = xbmcaddon.Addon(id='plugin.video.belgium')
Note: Manual copy to addon folder.
edit\
Yups, it is, works now.
i will take a look to the version 13.2 tomorrow ,...
or for the end of the week
thx for the informations,....
a my sense it must not difficult to resolve that,...
Edit,... ok
still to test
(2014-07-30, 01:40)alamata Wrote: [ -> ]i will take a look to the version 13.2 tomorrow ,...
Also check path FirebugLog, it's not there
<error>
sorry for the incovenient i have modified the zip jsut before upload it,....Confused
just create a folder named ""FirebugLog""
EDIT in the resources folder of the addon
install firefox if it s not done
start with the argument -p
create un new profil and browse to
XBMC\addons\plugin.video.dinoxC\resources\FireFoxProfile\tdpf2upa.default
and make the update of FF if necessary
adjust the advanced setting of the addon to your internet connection speed
go to debug to show the automation
(2014-07-30, 01:54)alamata Wrote: [ -> ]sorry for the incovenient i have modified the zip jsut before upload it,....Confused
So it depends on FF?
If so, it's a bad thing imo. At least for general usage of this addon.
in fact it use selenium and FF
How do I combine depencies with dinotube to work on gotham 13.1
hey ,...
here is the solution,...
NEW UPDATE to Gotham 13.2 see first POST for Changes
Hey,...
since around the 20 April 2015 the dinotube's site has changed his structure
So see the fisrt post the have the new update with version 0.0.5 for the dinotube addon for Kodi,...
Pages: 1 2
