Have spend a long time to get XBMC to work on Dell laptop Vostro 3500 i3. XBMCbuntu does not boot. XBMC inside Ubuntu 14.04 freezes when tyring to open XBMC. XBMC inside Linux Mint works perfectly ...
Than you LINUX MINT!!!!!!!
The only problem I have now is getting the HDMI to work!!
Why is your font so big? Are you ?
Tapatalk doesn't add those tags. He had an x-large tag which is now gone.
why are you so concerned about the font size ... whats more important is the content ... moreover .. wysiwyg allows any font size to be used without restriction
Yeah we propably should change that fact ...
there is also a reasonable expectation that you won't abuse a stupidly absurd font size. i guess what we see is not what we get.
I was just wondering if you were doing it manually or if it was something being added by a program. Now that I know you are doing it manually I can safely ignore the post, as using large fonts, colors, or Comic Sans, for no reason, is annoying as heck. Cheers.
To answer your question: The font size is rude and distracting. The content isn't much better.
Moved the entire thing to off-topic.
