Full Version: How to get numbers on tv show list
Hi.
Couldnt find anything on this so i hope you can help me.
When i upgraded from Frodo to Gotham and also updated the skin Aeon Nox the view on new episodes in tv show category changed from numbers to stars.
Im sorry i dont have any print screen, at work at the moment.
Do anyone knows how i can put numbers of episodes not seen in the corner instead of stars?
Oh btw, does anyone knows why XBMC is listing empty folders as if there are episodes not seen?
Hope you understand my problem.
Hallon83
Windows 8.1 - XBMC Gotham 13 - Aeon Nox 5.0
Ok so anyone has any ideas on what setting it might be that does this?
I have added a picture on how it looks, in the earlier version i got numbers that showed how many episodes not seen and so on instead of stars. And those folders that are shown is empty but is marked as if there are new episodes.
I have tried to do a clean of the library and also marked it as seen but nothing happens. Please help me.
Edit:
Oh and the image preview doesnt seem to work but you can right click and save it and it works.
Hallon83
Have you checked or asked for advice on the aeon nox thread. Sounds more a skin issue rather than a windows application issue.
Ok, thanks, will try that.
