Settings -> Skin Settings -> Backgrounds -> Home - Movies
When Fanart is selected in this setting movie fanart is displayed on the movie home menu inside a picture of a movie screen. The same thing happens for music (a picture of a iPhone screen) and tv shows (a picture of a TV). How can I make the fanart show full screen?
http://postimg.org/image/asimdo6cx/
If you can tolerate that you need to localize your fanart to the same folder you can try this: go settings -> skin settings -> backgrounds > home - movies. Instead of "fanart" select "multi image". Browse to the folder where your fanart is stored and select that folder.
You can collect your fanart to the same folder manually or use artwork downloader to scape all that stuff. I would use downloader. Time saver.
Haven't tried that though, but it might work.
(2014-07-30, 22:25)weirdinin Wrote: [ -> ]If you can tolerate that you need to localize your fanart to the same folder you can try this: go settings -> skin settings -> backgrounds > home - movies. Instead of "fanart" select "multi image". Browse to the folder where your fanart is stored and select that folder.
Good idea. I already put my fanart into a one folder because the "fanart" selection will not work otherwise. Just need to select multi-image instead of fanart and then point it to the same folder.
