Full Version: Local Information Only 'scraper'
Running XBMC 13.1 and trying to use externally maintained library with .NFO files and graphics files (fanart.jpg, poster.jpg, etc)
I've set up my Movies sources specifying the directory is 'Movies' and using the 'Local Information Only' scraper.
I've also set up my TV Show sources specifying the directory is 'TV Shows' and using the 'Local Information Only' scraper.
I'm having issues with some skins where the Random Movie fanart backgrounds are turning up blank for some fanarts (and only for movie fanarts)
What I'm finding is that the movie fanarts that turn out blank do not have an entry in the Textures database.
(I can still highlight the movie in the library and the fanart appears in the background - it's just the random fanarts on the home menu)
When I scan my Movies library with Local Information Only scraper set, should this be updating the Textures database, or how does this get populated?
The TV Shows appear to have all their fanart populated in the Textures database.
