2015-04-17, 19:32
Those of you having trouble sounds like your trying to install using the "install from zip file" to my knowledge you have to maually copy the folder into the addon folder which i dont know how to do on openelect
(2015-03-16, 13:54)duntuk Wrote: [ -> ]Just updated the skin to fully work with KODI...
Now...
About the play/pause button highlight... I made it that way on purpose for 2 reasons:
1. Primary focus of most important element. I wanted the play/pause button to be clearly visible at all times, since it's the main button used most of the time.
2. Mouse compatibility. When using only a mouse, there is a player control button focus bug that triggers the focus state of a single button (usually play/pause) when moving the mouse anywhere across the screen. In other words, what happens when you move the mouse around, the play/pause button flickers on/off. (This is the case with most (all?) skins I have tested)...
The other option I messed around with in order to prevent 2 blue buttons at the same time, was to change the circle color of the other control buttons... However, I went back to the same blue, since it took away from the color uniformity as a whole (i.e. I wanted to keep it as minimalist as possible at least with the colors)...
Anyhow...
If I have more time or get a bunch of similar requests, I'll add additional color schemes...
Nevertheless, I'm surprised that the KODI team has yet to update the appearance of their default Confluence theme... It's been years... And it's definitely not anything difficult to accomplish--it only took me a couple of days (on my first skinning attempt) to change up all the images.
(2015-04-17, 19:11)dabazz Wrote: [ -> ]The file in the first post is now corrected, no double archive but still get the 'add-On doesn't have the correct structure' error.
I'm on RaspberryPi using OpenELEC 5.0.8
(2015-04-17, 19:32)freddy12 Wrote: [ -> ]Those of you having trouble sounds like your trying to install using the "install from zip file" to my knowledge you have to maually copy the folder into the addon folder which i dont know how to do on openelect
(2015-04-20, 12:00)matteo2 Wrote: [ -> ](2015-04-17, 19:11)dabazz Wrote: [ -> ]The file in the first post is now corrected, no double archive but still get the 'add-On doesn't have the correct structure' error.
Same problem for me
I'd like to know where is this addon folder on RaspberryPi using OpenELEC 5.0.8
(2015-04-20, 13:27)csteinforth Wrote: [ -> ]To my knowledge it must be /storage/.kodi/addons. Please correct me if I'm wrong.
(2015-04-21, 13:29)matteo2 Wrote: [ -> ](2015-04-20, 13:27)csteinforth Wrote: [ -> ]To my knowledge it must be /storage/.kodi/addons. Please correct me if I'm wrong.
I extract the zip into /storage/.kodi/addons but when I search skin from settings I didn't find it... How can I install now?
(2015-04-23, 07:46)csteinforth Wrote: [ -> ]I tried the following and it worked:
- unzip the file
- rezip the folder
- upload the zip to OpenELEC
- install from zip
I'm using Ubuntu 14.04.
(2015-04-24, 10:08)matteo2 Wrote: [ -> ](2015-04-23, 07:46)csteinforth Wrote: [ -> ]I tried the following and it worked:
- unzip the file
- rezip the folder
- install from zip
And so I don't have to copy in /storage/.kodi/addons if I can install from zip...
(2015-06-01, 13:32)jeroendj2 Wrote: [ -> ]If someone could fix the zip would be great, would like to install this on my Raspberry Pi
Installed it on my desktop by placing the extracted zip in the add-on folder.
(2015-04-23, 07:46)csteinforth Wrote: [ -> ](2015-04-21, 13:29)matteo2 Wrote: [ -> ](2015-04-20, 13:27)csteinforth Wrote: [ -> ]To my knowledge it must be /storage/.kodi/addons. Please correct me if I'm wrong.
- unzip the file
- rezip the folder
- install from zip
