2014-08-02, 07:44
Been using XBMCbuntu and the latest Gotham for two weeks now and recently the DTS-HD and EAC3 options disappeared even though my receiver support them.
Here is the start of the log.
Here is the full log.
http://pastebin.com/Wf4ETJ5X
15:30:35 T:139690645690304 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:30:35 T:139690645690304 NOTICE: -----------------------------------------------------------------------
15:30:35 T:139690645690304 NOTICE: Starting XBMC (13.1 Git:f2acae7). Platform: x86 Linux 64-bit
15:30:35 T:139690645690304 NOTICE: Using Release XBMC x64 build, compiled Jun 6 2014 by GCC 4.8.2 for x86 Linux 64-bit 3.13.11
15:30:35 T:139690645690304 NOTICE: Running on Linux 64-bit (Ubuntu 14.04.1 LTS, 3.13.0-32-generic x86_64)
15:30:35 T:139690645690304 NOTICE: Host CPU: AMD A4-6320 APU with Radeon(tm) HD Graphics, 2 cores available
15:30:35 T:139690645690304 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
15:30:35 T:139690645690304 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
15:30:35 T:139690645690304 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
15:30:35 T:139690645690304 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
15:30:35 T:139690645690304 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
15:30:35 T:139690645690304 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
15:30:35 T:139690645690304 NOTICE: Local hostname: xbmc-tv
15:30:35 T:139690645690304 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
15:30:36 T:139690645690304 NOTICE: load settings...
15:30:36 T:139690645690304 ERROR: PulseAudio: Failed to connect context
15:30:36 T:139690645690304 NOTICE: PulseAudio might not be running. Context was not created.
15:30:36 T:139690645690304 NOTICE: CAESinkALSA::EnumerateDevice data format "AE_FMT_DTSHD" on device "hdmi:CARD=HDMI,DEV=0" seems to be not supported.
15:30:36 T:139690645690304 NOTICE: CAESinkALSA::EnumerateDevice data format "AE_FMT_TRUEHD" on device "hdmi:CARD=HDMI,DEV=0" seems to be not supported.
15:30:36 T:139690645690304 NOTICE: CAESinkALSA::EnumerateDevice data format "AE_FMT_EAC3" on device "hdmi:CARD=HDMI,DEV=0" seems to be not supported.
15:30:36 T:139690645690304 NOTICE: CAESinkALSA::EnumerateDevice data format "AE_FMT_AAC" on device "hdmi:CARD=HDMI,DEV=0" seems to be not supported.
15:30:36 T:139690645690304 NOTICE: Found 1 Lists of Devices
15:30:36 T:139690645690304 NOTICE: Enumerated ALSA devices:
15:30:36 T:139690645690304 NOTICE: Device 1
15:30:36 T:139690645690304 NOTICE: m_deviceName : default
15:30:36 T:139690645690304 NOTICE: m_displayName : Default (HDA ATI HDMI HDMI 0)
15:30:36 T:139690645690304 NOTICE: m_displayNameExtra:
15:30:36 T:139690645690304 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:30:36 T:139690645690304 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
15:30:36 T:139690645690304 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000
15:30:36 T:139690645690304 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
15:30:36 T:139690645690304 NOTICE: Device 2
15:30:36 T:139690645690304 NOTICE: m_deviceName : hdmi:CARD=HDMI,DEV=0
15:30:36 T:139690645690304 NOTICE: m_displayName : HDA ATI
15:30:36 T:139690645690304 NOTICE: m_displayNameExtra: @@@
15:30:36 T:139690645690304 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:30:36 T:139690645690304 NOTICE: m_channels : FL,FR,LFE,FC,BL,BR
15:30:36 T:139690645690304 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_AAC,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
15:30:36 T:139690645690304 NOTICE: Device 3
15:30:36 T:139690645690304 NOTICE: m_deviceName : @:CARD=Generic,DEV=0
15:30:36 T:139690645690304 NOTICE: m_displayName : HD-Audio Generic
15:30:36 T:139690645690304 NOTICE: m_displayNameExtra: ALC1150 Analog
15:30:36 T:139690645690304 NOTICE: m_sampleRates : 48000
15:30:36 T:139690645690304 NOTICE: Device 4
15:30:36 T:139690645690304 NOTICE: m_deviceName : iec958:CARD=Generic,DEV=0
15:30:36 T:139690645690304 NOTICE: m_displayNameExtra: ALC1150 Digital S/PDIF
15:30:36 T:139690645690304 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
15:30:36 T:139690645690304 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
15:30:36 T:139690645690304 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
