it works for me and i don't know what's wrong with your setup. please check if you could map another command to your button and if it works.
Make sure you have the mapping defined under <global> and not some subsection.
you don't need to place it in your userdata folder because that's the default keymap file for remotes which is shipped with xbmc. you only need to override keys in your own keymap file if you want to use a different cmd.
Yeah i know but i cant get XBMC.ActivateWindow(TVGuide) to work from <global> or <home> only works under <FullscreenLiveTV>
Can you post a debug log?
and please post your remote.xml too
http://xbmclogs.com/show.php?id=261523
19:15:54 47.175022 T:3060084736 DEBUG: LIRC: Update - NEW at 35195:16d 0 KEY_EPG devinput (KEY_EPG)
19:15:54 47.175636 T:3060084736 DEBUG: OnKey: 229 (0xe5) pressed, action is ContextMenu
19:15:55 47.886951 T:3060084736 DEBUG: LIRC: Update - NEW at 35907:16d 0 KEY_EPG_UP devinput (KEY_EPG_UP)
19:16:00 53.369598 T:3060084736 DEBUG: LIRC: Update - NEW at 41390:16d 0 KEY_EPG devinput (KEY_EPG)
19:16:00 53.370480 T:3060084736 DEBUG: OnKey: 229 (0xe5) pressed, action is ContextMenu
19:16:01 53.957031 T:3060084736 DEBUG: LIRC: Update - NEW at 41977:16d 0 KEY_EPG_UP devinput (KEY_EPG_UP)
http://xbmclogs.com/show.php?id=261524
Check you Lircmap.xml, I suspect KEY_EPG is not mapped to <guide>.
Yes your right Thanks ! Lircmap
http://xbmclogs.com/show.php?id=261581
Lircmap.xml is OpenElecs problem right ?
Solved by
<?xml version="1.0" encoding="UTF-8"?>
<!-- This file contains the mapping of LIRC keys to XBMC keys used in Keymap.xml -->
<!-- How to add remotes -->
<!-- <remote device="name_Lirc_calls_the_remote"> -->
<!-- For the commands the layout following layout is used -->
<!-- <XBMC_COMMAND>LircButtonName</XBMC_COMMAND> -->
<!-- For a list of XBMC_COMMAND's check out the <remote> sections of keymap.xml -->
<lircmap>
<remote device="mceusb">
<play>Play</play>
<pause>Pause</pause>
<stop>Stop</stop>
<forward>Forward</forward>
<reverse>Rewind</reverse>
<left>Left</left>
<right>Right</right>
<up>Up</up>
<down>Down</down>
<select>OK</select>
<guide>KEY_EPG</guide>
<pageplus>ChanUp</pageplus>
<pageminus>ChanDown</pageminus>
<back>Back</back>
<menu>DVD</menu>
<title>Guide</title>
<info>More</info>
<skipplus>Skip</skipplus>
<skipminus>Replay</skipminus>
<display>Aspect</display>
<start>Home</start>
<record>Record</record>
<volumeplus>VolUp</volumeplus>
<volumeminus>VolDown</volumeminus>
<mute>Mute</mute>
<power>Power</power>
<myvideo>Videos</myvideo>
<mymusic>Music</mymusic>
<mypictures>Pictures</mypictures>
<mytv>TV</mytv>
<one>One</one>
<two>Two</two>
<three>Three</three>
<four>Four</four>
<five>Five</five>
<six>Six</six>
<seven>Seven</seven>
<eight>Eight</eight>
<nine>Nine</nine>
<zero>Zero</zero>
<star>Star</star>
<hash>Hash</hash>
<clear>Clear</clear>
<enter>Enter</enter>
<red>Red</red>
<green>Green</green>
<yellow>Yellow</yellow>
<blue>Blue</blue>
<teletext>Teletext</teletext>
<!-- new kernel-based lirc button names -->
<eject>KEY_EJECTCD</eject>
<left>KEY_LEFT</left>
<right>KEY_RIGHT</right>
<up>KEY_UP</up>
<down>KEY_DOWN</down>
<select>KEY_OK</select>
<start>KEY_HOME</start>
<back>KEY_BACK</back>
<record>KEY_RECORD</record>
<play>KEY_PLAY</play>
<pause>KEY_PAUSE</pause>
<stop>KEY_STOP</stop>
<forward>KEY_FORWARD</forward>
<reverse>KEY_REWIND</reverse>
<volumeplus>KEY_VOLUMEUP</volumeplus>
<volumeminus>KEY_VOLUMEDOWN</volumeminus>
<pageplus>KEY_CHANNELUP</pageplus>
<pageminus>KEY_CHANNELDOWN</pageminus>
<skipplus>KEY_NEXT</skipplus>
<skipminus>KEY_AGAIN</skipminus>
<mute>KEY_MUTE</mute>
<power>KEY_POWER</power>
<myvideo>KEY_VIDEO</myvideo>
<mymusic>KEY_AUDIO</mymusic>
<mytv>LiveTV</mytv>
<one>KEY_1</one>
<two>KEY_2</two>
<three>KEY_3</three>
<four>KEY_4</four>
<five>KEY_5</five>
<six>KEY_6</six>
<seven>KEY_7</seven>
<eight>KEY_8</eight>
<nine>KEY_9</nine>
<zero>KEY_0</zero>
<red>KEY_RED</red>
<green>KEY_GREEN</green>
<yellow>KEY_YELLOW</yellow>
<blue>KEY_BLUE</blue>
<menu>KEY_DVD</menu>
<clear>KEY_CLEAR</clear>
<enter>KEY_ENTER</enter>
</remote>
<remote device="XboxDVDDongle">
<play>PLAY</play>
<pause>PAUSE</pause>
<stop>STOP</stop>
<forward>FORWARD</forward>
<reverse>REVERSE</reverse>
<left>LEFT</left>
<right>RIGHT</right>
<up>UP</up>
<down>DOWN</down>
<select>SELECT</select>
<back>BACK</back>
<menu>MENU</menu>
<title>TITLE</title>
<info>INFO</info>
<skipplus>SKIP+</skipplus>
<skipminus>SKIP-</skipminus>
<display>DISPLAY</display>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
</remote>
<remote device="Microsoft_Xbox">
<play>PLAY</play>
<stop>STOP</stop>
<left>LEFT</left>
<up>UP</up>
<down>DOWN</down>
<back>BACK</back>
<menu>MENU</menu>
<info>INFO</info>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
</remote>
<remote device="PinnacleSysPCTVRemote">
<play>Play</play>
<pause>pause</pause>
<stop>Stop</stop>
<forward>FForward</forward>
<left>Vol-Rew</left>
<right>Vol+FF</right>
<up>Chan+Play</up>
<down>Chan-Stop</down>
<pageplus>channel+</pageplus>
<pageminus>channel-</pageminus>
<select>middle</select>
<back>undo</back>
<menu>Menu</menu>
<title>L</title>
<info>Info</info>
<skipplus>next</skipplus>
<display>Fullscreen</display>
<volumeplus>vol+</volumeplus>
<volumeminus>vol-</volumeminus>
<mute>Mute</mute>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
</remote>
<remote device="anysee">
<stop>stop</stop>
<forward>f1</forward>
<reverse>f2</reverse>
<left>left</left>
<right>right</right>
<up>chan-up</up>
<down>chan-down</down>
<select>ok</select>
<back>exit</back>
<menu>menu</menu>
<title>play</title>
<info>info</info>
<skipplus>jump-fwd</skipplus>
<skipminus>jump-back</skipminus>
<display>size</display>
<start>star</start>
<record>rec</record>
<volumeplus></volumeplus>
<volumeminus></volumeminus>
<mute>mute</mute>
<power>power</power>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
<red>red</red>
<green>green</green>
<yellow>yellow</yellow>
<blue>blue</blue>
<subtitle>subtitle</subtitle>
<language>audio</language>
</remote>
<remote device="iMON-PAD">
<play>Play</play>
<stop>Stop</stop>
<forward>FastForward</forward>
<left>Left</left>
<up>Up</up>
<down>Down</down>
<select>Enter</select>
<pageplus>Ch+</pageplus>
<pageminus>Ch-</pageminus>
<back>Esc</back>
<back>Backspace</back>
<menu>Multimon</menu>
<title>MouseMenu</title>
<info>SelectSpace</info>
<skipplus>NextChapter</skipplus>
<skipminus>PrevChapter</skipminus>
<display>FullScreen</display>
<start>MultiMon</start>
<volumeplus>Vol+</volumeplus>
<volumeminus>Vol-</volumeminus>
<mute>Mute</mute>
<myvideo>MyMovie</myvideo>
<mymusic>MyMusic</mymusic>
<mypictures>MyPhoto</mypictures>
<mytv>MyTV</mytv>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
<subtitle>Language</subtitle>
</remote>
<remote device="Antec_Veris_RM200">
<forward>KEY_FASTFORWARD</forward>
<up>KEY_UP</up>
<select>KEY_ENTER</select>
<back>KEY_BACKSPACE</back>
<menu>KEY_MENU</menu>
<info>Go</info>
<skipminus>prev</skipminus>
<start>applauncher</start>
<mypictures>KEY_PHOTO</mypictures>
<mytv>KEY_TV</mytv>
<one>KEY_1</one>
<two>KEY_2</two>
<four>KEY_4</four>
<five>KEY_5</five>
<six>KEY_6</six>
<nine>KEY_9</nine>
<zero>KEY_0</zero>
<star>Star</star>
<hash>Hash</hash>
<playlist>KEY_BOOKMARKS</playlist>
<teletext>Thumbnail</teletext>
<title>TaskSwitcher</title>
</remote>
<remote device="MCE_via_iMON">
<up>KEY_UP</up>
<menu>PreviousMenu</menu>
<info>KEY_INFO</info>
<skipplus>KEY_SKIP</skipplus>
<skipminus>KEY_REPLAY</skipminus>
<display>Teletext</display>
<start>WindowsMCE</start>
<mytv>KEY_TV</mytv>
<one>KEY_ONE</one>
<two>KEY_TWO</two>
<three>KEY_THREE</three>
<four>KEY_FOUR</four>
<five>KEY_FIVE</five>
<six>KEY_SIX</six>
<seven>KEY_SEVEN</seven>
<eight>KEY_EIGHT</eight>
<nine>KEY_NINE</nine>
<zero>KEY_ZERO</zero>
<star>Star</star>
<hash>Hash</hash>
<clear>KEY_DELETE</clear>
<red>Red</red>
<blue>Blue</blue>
</remote>
<remote device="TwinHanRemote">
<display>fullscreen</display>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
<myvideo>favorite</myvideo>
<volumeminus>rewind</volumeminus>
<volumeplus>forward</volumeplus>
<up>ch+</up>
<left>vol-</left>
<select>play</select>
<right>vol+</right>
<down>ch-</down>
<menu>recall</menu>
<stop>stop</stop>
<mute>mute</mute>
<info>epg</info>
<recordedtv>recordlist</recordedtv>
<title>teletext</title>
</remote>
<remote device="linux-input-layer">
<altname>cx23885_remote</altname>
<up>KEY_UP</up>
<start>KEY_SELECT</start>
<start>KEY_PROG1</start>
<back>KEY_ESC</back>
<back>KEY_EXIT</back>
<back>KEY_CLOSE</back>
<play>KEY_PLAYPAUSE</play>
<stop>KEY_STOPCD</stop>
<channelplus>KEY_CHANNELUP</channelplus>
<channelminus>KEY_CHANNELDOWN</channelminus>
<skipplus>KEY_NEXTSONG</skipplus>
<skipminus>KEY_PREVIOUSSONG</skipminus>
<skipminus>KEY_PREVIOUS</skipminus>
<title>KEY_TITLE</title>
<subtitle>KEY_SUBTITLE</subtitle>
<language>KEY_LANGUAGE</language>
<mypictures>KEY_MHP</mypictures>
<mypictures>KEY_CAMERA</mypictures>
<mytv>KEY_TV</mytv>
<liveradio>KEY_RADIO</liveradio>
<mytv>KEY_TUNER</mytv>
<one>KEY_1</one>
<two>KEY_2</two>
<four>KEY_4</four>
<five>KEY_5</five>
<six>KEY_6</six>
<nine>KEY_9</nine>
<zero>KEY_0</zero>
<one>KEY_NUMERIC_1</one>
<two>KEY_NUMERIC_2</two>
<three>KEY_NUMERIC_3</three>
<four>KEY_NUMERIC_4</four>
<five>KEY_NUMERIC_5</five>
<six>KEY_NUMERIC_6</six>
<seven>KEY_NUMERIC_7</seven>
<eight>KEY_NUMERIC_8</eight>
<nine>KEY_NUMERIC_9</nine>
<zero>KEY_NUMERIC_0</zero>
<star>KEY_NUMERIC_STAR</star>
<hash>KEY_NUMERIC_POUND</hash>
<red>KEY_RED</red>
<info>KEY_PROPS</info>
<display>KEY_ANGLE</display>
<display>KEY_ZOOM</display>
<recordedtv>KEY_PVR</recordedtv>
<teletext>KEY_TEXT</teletext>
</remote>
<remote device="mediacenter">
<stop>stop</stop>
<forward>fwd</forward>
<reverse>rew</reverse>
<left>left</left>
<up>up</up>
<down>down</down>
<select>ok</select>
<pageplus>ch+</pageplus>
<pageminus>ch-</pageminus>
<back>back</back>
<menu>clear</menu>
<title>play</title>
<info>info</info>
<display>teletext</display>
<start>ehome</start>
<mute>mute</mute>
<myvideo>video</myvideo>
<mymusic>music</mymusic>
<mypictures>pictures</mypictures>
<mytv>tv</mytv>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
<mytv>red</mytv>
<mymusic>green</mymusic>
<mypictures>yellow</mypictures>
<myvideo>blue</myvideo>
</remote>
<remote device="devinput">
<up>KEY_UP</up>
<start>KEY_MEDIA</start>
<eject>KEY_EJECTCLOSECD</eject>
<red>KEY_RED</red>
</remote>
</lircmap>
No, it's an XBMC problem too. Create a bug report on trac and attach your modified Lircmap.xml, you can add me as CC.
