Full Version: Overriding system keymap.xml
I'm trying to override system keymap.xml. As I see I need to create a keyboard.xml file in userdata/keymaps directory. It works form me with this sample:
<?xml version="1.0" encoding="UTF-8"?>
<keymap>
<global>
    <keyboard>
      <q mod="ctrl">Notification(Key, q, 3)</q>
    </keyboard>
  </global>
  <window3000>
    <keyboard>
      <f7 mod="ctrl">info</f7>
    </keyboard>
  </window3000>
  <window3001>
    <keyboard>
    </keyboard>
  </window3001>
</keymap>
I override one global key and the f7 key for two custom windows. The problem becomes when I want to override a global key, for example the k key. In the system file this key has this value:
<keymap>
  <global>
    <keyboard>
      <p>Play</p>
      <k>XBMC.ActivateWindow(TVRecordings)</k>
    </keyboard>
  </global>
I want to override the k key with the k key. Yes I want the key k do nothing. I try with:
<k></k>
<k>-</k>
<k>k</k>
But I always get the same result, which is the activation of system file key. It seems like the key is not to overridable.
Any suggentions?
Thanks in advance
You need to use <k>noop</k>.
Hi `Black,
thanks. It work fine.
Best regards
