I use art downloader to download my art for Covers.. Some of the covers fit within the box and some don't. the images seem larger than Xbmc allows. Can I edit size the image is displayed within xbmc or do I have to manually edit them all to fit?
see this link for a visual
http://i.imgur.com/d506bPU.jpg
It's because BigNoid use ratio="scale" and not ratio ="stretch" for resizing poster, so image is cropped.
Look into my mod, I have modified this view so you can look into View_53_ShowCase.xml to see where you can change scale to stretch :
http://forum.xbmc.org/showthread.php?tid=195665
Hi Mikebzh44,
I have downloaded your mod and searched for Ratio="stretch" within View_53_ShowCase.xml and i am unable to find it. Could ou please tell me what line it is on.
Edit your View_53_Showcase.xml, search for <include name="MovieShowcaseThumb"> and <include name="MovieShowcaseThumbReflection"> and replace
scale by
stretch.
Should be lines 740 and 747 in original View_53_Showcase.xml file :
https://github.com/BigNoid/Aeon-Nox/blob...owCase.xml
Thankyou!! i had looked at that line a few times but as it didn't match your search suggestion i was apprehensive to change it.
