2014-08-06, 20:48
I just upgraded to Gotham from Frodo today and noticed that my volume on all my videos just seemed to amplify a good bit after installing. With Frodo I would normally have my computers soundcard volume at max and would be able to watch the videos with sound being in the range of -26 to -18 decibels and it would be alright. Upon installing Gotham however it would be like that for the first use, but after that the volume would drop to -50db and it would still sound the same as if it did before. Anyone else have this issue? What can I do to fix it? I am running Linux Mint 17 Kernel Version 3.15.8. Here is my debug log:
13:29:25 T:140146126776256 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:29:25 T:140146126776256 NOTICE: -----------------------------------------------------------------------
13:29:25 T:140146126776256 NOTICE: Starting XBMC (13.1 Git:f2acae7). Platform: x86 Linux 64-bit
13:29:25 T:140146126776256 NOTICE: Using Release XBMC x64 build, compiled Jun 6 2014 by GCC 4.8.2 for x86 Linux 64-bit 3.13.11
13:29:25 T:140146126776256 NOTICE: Running on Linux 64-bit (Ubuntu 14.04.1 LTS, 3.15.8-031508-generic x86_64)
13:29:25 T:140146126776256 NOTICE: Host CPU: Intel® Core i7-3630QM CPU @ 2.40GHz, 8 cores available
13:29:25 T:140146126776256 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
13:29:25 T:140146126776256 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
13:29:25 T:140146126776256 NOTICE: special://masterprofile/ is mapped to: /home/joey/.xbmc/userdata
13:29:25 T:140146126776256 NOTICE: special://home/ is mapped to: /home/joey/.xbmc
13:29:25 T:140146126776256 NOTICE: special://temp/ is mapped to: /home/joey/.xbmc/temp
13:29:25 T:140146126776256 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
13:29:25 T:140146126776256 NOTICE: Local hostname: joey-CZ-17
13:29:25 T:140146126776256 NOTICE: Log File is located: /home/joey/.xbmc/temp/xbmc.log
13:29:25 T:140146126776256 WARNING: CXRandR::Query - output LVDS1 has no current mode, assuming disconnected
13:29:25 T:140146126776256 NOTICE: load settings...
13:29:25 T:140146126776256 NOTICE: Found 1 Lists of Devices
13:29:25 T:140146126776256 NOTICE: Enumerated PULSE devices:
13:29:25 T:140146126776256 NOTICE: Device 1
13:29:25 T:140146126776256 NOTICE: m_deviceName : Default
13:29:25 T:140146126776256 NOTICE: m_displayName : Default
13:29:25 T:140146126776256 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
13:29:25 T:140146126776256 NOTICE: m_deviceType : AE_DEVTYPE_PCM
13:29:25 T:140146126776256 NOTICE: m_channels : FL,FR
13:29:25 T:140146126776256 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
13:29:25 T:140146126776256 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_S16NE,AE_FMT_S24LE3,AE_FMT_S24BE3,AE_FMT_S24NE3,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S24NE4,AE_FMT_S32BE,AE_FMT_S32LE,AE_FMT_S32NE,AE_FMT_FLOAT
13:29:25 T:140146126776256 NOTICE: Device 2
13:29:25 T:140146126776256 NOTICE: m_deviceName : alsa_output.pci-0000_01_00.1.hdmi-stereo
13:29:25 T:140146126776256 NOTICE: m_displayName : GK104 HDMI Audio Controller Digital Stereo (HDMI)
13:29:25 T:140146126776256 NOTICE: m_displayNameExtra: HDMI / DisplayPort (PULSEAUDIO)
13:29:25 T:140146126776256 NOTICE: Device 3
13:29:25 T:140146126776256 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
13:29:25 T:140146126776256 NOTICE: m_displayName : Built-in Audio Analog Stereo
13:29:25 T:140146126776256 NOTICE: m_displayNameExtra: Analog Output (PULSEAUDIO)
13:29:25 T:140146126776256 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:29:25 T:140146126776256 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
13:29:25 T:140146126776256 NOTICE: Default DVD Player: dvdplayer
13:29:25 T:140146126776256 NOTICE: Default Video Player: dvdplayer
13:29:25 T:140146126776256 NOTICE: Default Audio Player: paplayer
13:29:25 T:140146126776256 NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:29:25 T:140146126776256 NOTICE: Log level changed to 0
13:29:25 T:140146126776256 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
13:29:25 T:140146126776256 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:29:25 T:140146126776256 NOTICE: Loaded playercorefactory configuration
13:29:25 T:140146126776256 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:29:25 T:140146126776256 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:29:25 T:140145665328896 NOTICE: Thread ActiveAE start, auto delete: false
13:29:25 T:140145729521408 NOTICE: Thread AESink start, auto delete: false
13:29:25 T:140146126776256 NOTICE: Running database version Addons16
13:29:25 T:140146126776256 NOTICE: ADDONS: Using repository repository.xbmc.org
13:29:25 T:140145703532288 NOTICE: Thread PeripBusCEC start, auto delete: false
13:29:25 T:140145695139584 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
13:29:25 T:140146126776256 NOTICE: Setup SDL
13:29:25 T:140146126776256 NOTICE: Checking resolution 16
13:29:25 T:140146126776256 NOTICE: Using visual 0x21
13:29:25 T:140146126776256 NOTICE: GL_VENDOR = Intel Open Source Technology Center
13:29:25 T:140146126776256 NOTICE: GL_RENDERER = Mesa DRI Intel® Ivybridge Mobile
13:29:25 T:140146126776256 NOTICE: GL_VERSION = 3.0 Mesa 10.1.3
13:29:25 T:140146126776256 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
13:29:25 T:140146126776256 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix
13:29:25 T:140146126776256 ERROR: GLX: Same window as before, refreshing context
13:29:25 T:140146126776256 NOTICE: No Joystick name specified, loading default map
13:29:25 T:140146126776256 NOTICE: Previous line repeats 35 times.
13:29:25 T:140146126776256 NOTICE: Running database version ViewModes6
13:29:25 T:140146126776256 NOTICE: Running database version Textures13
13:29:25 T:140146126776256 NOTICE: Running database version MyMusic46
13:29:25 T:140146126776256 NOTICE: Running database version MyVideos78
13:29:25 T:140146126776256 NOTICE: Running database version TV22
13:29:25 T:140146126776256 NOTICE: Running database version Epg7
13:29:25 T:140146126776256 NOTICE: start dvd mediatype detection
13:29:25 T:140146126776256 NOTICE: initializing playlistplayer
13:29:25 T:140146126776256 NOTICE: DONE initializing playlistplayer
13:29:25 T:140146126636800 NOTICE: Thread DetectDVDMedia start, auto delete: false
13:29:25 T:140146126776256 ERROR: Couldn't load font name: font-16d(digital-readout.ttf), trying to substitute arial.ttf
13:29:26 T:140146126776256 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
13:29:26 T:140146126776256 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
13:29:26 T:140144974714624 NOTICE: Thread LanguageInvoker start, auto delete: false
13:29:26 T:140144974714624 NOTICE: Previous line repeats 2 times.
13:29:26 T:140144974714624 NOTICE: -->Python Interpreter Initialized<--
13:29:26 T:140144983107328 NOTICE: -->Python Interpreter Initialized<--
13:29:26 T:140144966321920 NOTICE: -->Python Interpreter Initialized<--
13:29:26 T:140144956618496 NOTICE: Thread JobWorker start, auto delete: true
13:29:26 T:140146126776256 NOTICE: UpdateLibraries - Starting video library startup scan
13:29:26 T:140144946652928 NOTICE: Thread VideoInfoScanner start, auto delete: false
13:29:26 T:140146126776256 NOTICE: initialize done
13:29:26 T:140144938260224 NOTICE: Thread LanguageInvoker start, auto delete: false
13:29:26 T:140146126776256 NOTICE: Running the application...
13:29:26 T:140146126776256 NOTICE: starting zeroconf publishing
13:29:26 T:140146126776256 NOTICE: Webserver: Starting...
13:29:26 T:140144581539584 NOTICE: Thread JobWorker start, auto delete: true
13:29:26 T:140146126776256 NOTICE: WebServer: Started the webserver
13:29:26 T:140146126776256 NOTICE: ES: Starting event server
13:29:26 T:140144556361472 NOTICE: Thread JobWorker start, auto delete: true
13:29:26 T:140144547968768 NOTICE: Thread EventServer start, auto delete: false
13:29:26 T:140144547968768 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:29:26 T:140144547968768 NOTICE: UDP: Listening on port 9777
13:29:26 T:140144539576064 NOTICE: Thread TCPServer start, auto delete: false
13:29:26 T:140144531183360 NOTICE: Thread JobWorker start, auto delete: true
13:29:26 T:140146126305024 NOTICE: Thread RSSReader start, auto delete: false
13:29:26 T:140144938260224 NOTICE: -->Python Interpreter Initialized<--
13:29:26 T:140144946652928 NOTICE: VideoInfoScanner: Starting scan ..
13:29:26 T:140143966959360 NOTICE: Thread LanguageInvoker start, auto delete: false
13:29:26 T:140144983107328 NOTICE: Thread AlarmClock start, auto delete: false
13:29:26 T:140144938260224 NOTICE: StorageServer Module loaded RUN
13:29:26 T:140144938260224 NOTICE: StorageClient-2.5.4 Starting server
13:29:26 T:140143966959360 NOTICE: -->Python Interpreter Initialized<--
13:29:26 T:140144946652928 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
13:29:38 T:140143966959360 NOTICE: Thread BackgroundLoader start, auto delete: false
13:29:45 T:140144956618496 NOTICE: Previous line repeats 3 times.
13:29:45 T:140144956618496 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:29:45 T:140146126776256 NOTICE: Previous line repeats 1 times.
13:29:45 T:140146126776256 NOTICE: DVDPlayer: Opening: /media/joey/TV Shows 2/TV Shows/The Americans (2013)/Season 1/the.americans.2013.s01e01.720p.bluray.x264-counterfeit.mkv
13:29:45 T:140146126776256 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
13:29:45 T:140143966959360 NOTICE: Thread DVDPlayer start, auto delete: false
13:29:45 T:140143966959360 NOTICE: Creating InputStream
13:29:45 T:140143966959360 NOTICE: Creating Demuxer
13:29:45 T:140143966959360 NOTICE: Opening video stream: 0 source: 256
13:29:45 T:140143966959360 NOTICE: Creating video codec with codec id: 28
13:29:45 T:140143966959360 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:29:45 T:140143801378560 NOTICE: Thread VideoReferenceClock start, auto delete: false
13:29:45 T:140143966959360 NOTICE: Creating video thread
13:29:45 T:140143709124352 NOTICE: Thread DVDPlayerVideo start, auto delete: false
13:29:45 T:140143709124352 NOTICE: running thread: video_thread
13:29:45 T:140143966959360 NOTICE: Opening audio stream: 1 source: 256
13:29:45 T:140143966959360 NOTICE: Finding audio codec for: 86020
13:29:45 T:140143966959360 NOTICE: Creating audio thread
13:29:45 T:140143700731648 NOTICE: Thread DVDPlayerAudio start, auto delete: false
13:29:45 T:140143700731648 NOTICE: running thread: CDVDPlayerAudio:rocess()
13:29:45 T:140143700731648 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through)
13:29:45 T:140143709124352 ERROR: VAAPI - unable to initialize display -1 - unknown libva error
13:29:45 T:140143709124352 NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating VDPAU(1280x720)
13:29:45 T:140143709124352 NOTICE: VDPAU::Open: required extension GL_NV_vdpau_interop not found
13:29:45 T:140143709124352 NOTICE: (VDPAU) Close
13:29:45 T:140143709124352 NOTICE: fps: 23.976024, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
13:29:45 T:140143709124352 NOTICE: Display resolution DESKTOP : 1920x1080@ 60.00 - Full Screen (16)
13:29:46 T:140146126776256 NOTICE: Using GL_TEXTURE_2D
13:29:46 T:140146126776256 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
13:29:46 T:140146126776256 NOTICE: GL: NPOT texture support detected
13:29:46 T:140146126776256 NOTICE: GL: Using GL_ARB_pixel_buffer_object
13:29:56 T:140143692338944 NOTICE: Thread LanguageInvoker start, auto delete: false
13:29:56 T:140143692338944 NOTICE: -->Python Interpreter Initialized<--
13:30:24 T:140146126776256 NOTICE: CDVDPlayer::CloseFile()
13:30:24 T:140146126776256 NOTICE: DVDPlayer: waiting for threads to exit
13:30:24 T:140143966959360 NOTICE: CDVDPlayer::OnExit()
13:30:24 T:140143966959360 NOTICE: DVDPlayer: closing audio stream
13:30:24 T:140143966959360 NOTICE: Closing audio stream
13:30:24 T:140143966959360 NOTICE: Waiting for audio thread to exit
13:30:24 T:140143700731648 NOTICE: thread end: CDVDPlayerAudio::OnExit()
13:30:24 T:140143966959360 NOTICE: Closing audio device
13:30:24 T:140143966959360 NOTICE: Deleting audio codec
13:30:24 T:140143966959360 NOTICE: DVDPlayer: closing video stream
13:30:24 T:140143966959360 NOTICE: Closing video stream
13:30:24 T:140143966959360 NOTICE: waiting for video thread to exit
13:30:24 T:140143709124352 NOTICE: thread end: video_thread
13:30:24 T:140143966959360 NOTICE: deleting video codec
13:30:24 T:140143966959360 NOTICE: CDVDPlayer::OnExit() deleting demuxer
13:30:24 T:140143966959360 NOTICE: CDVDPlayer::OnExit() deleting input stream
13:30:24 T:140146126776256 NOTICE: DVDPlayer: finished waiting
13:30:24 T:140143966959360 NOTICE: Thread BackgroundLoader start, auto delete: false
13:30:24 T:140143801378560 NOTICE: Thread JobWorker start, auto delete: true
13:30:25 T:140143801378560 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:30:25 T:140143966959360 NOTICE: Thread JobWorker start, auto delete: true
13:30:30 T:140143809771264 NOTICE: Previous line repeats 9 times.
13:30:30 T:140143809771264 NOTICE: Thread BackgroundLoader start, auto delete: false
13:30:30 T:140143966959360 WARNING: CreateLoader - Unsupported protocol(addons) in addons://sources/executable/fanart.jpg
13:30:30 T:140143809771264 NOTICE: Thread JobWorker start, auto delete: true
13:30:34 T:140144556361472 NOTICE: Previous line repeats 1 times.
13:30:34 T:140144556361472 NOTICE: Thread BackgroundLoader start, auto delete: false
13:31:03 T:140143801378560 NOTICE: Previous line repeats 1 times.
13:31:03 T:140143801378560 WARNING: CreateLoader - Unsupported protocol(addons) in addons://sources/executable/fanart.jpg
13:31:12 T:140146126776256 NOTICE: Storing total System Uptime
13:31:12 T:140146126776256 NOTICE: Saving settings
13:31:12 T:140146126776256 NOTICE: stop all
13:31:12 T:140146126776256 NOTICE: stop player
13:31:12 T:140146126776256 NOTICE: ES: Stopping event server
13:31:12 T:140146126776256 NOTICE: stopping zeroconf publishing
13:31:12 T:140146126776256 NOTICE: Webserver: Stopping...
13:31:12 T:140146126776256 NOTICE: WebServer: Stopped the webserver
13:31:12 T:140146126776256 NOTICE: Webserver: Stopped...
13:31:12 T:140144547968768 NOTICE: ES: UDP Event server stopped
13:31:12 T:140146126776256 NOTICE: stop dvd detect media
13:31:12 T:140146126776256 NOTICE: stop sap announcement listener
13:31:12 T:140146126776256 NOTICE: clean cached files!
13:31:12 T:140146126776256 NOTICE: unload skin
13:31:12 T:140144974714624 WARNING: CPythonInvoker(1, /home/joey/.xbmc/addons/service.skin.widgets/default.py): the python script "/home/joey/.xbmc/addons/service.skin.widgets/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE
13:31:12 T:140144938260224 NOTICE: StorageServer-2.5.4 Closed down
13:31:13 T:140146126776256 NOTICE: stopped
13:31:13 T:140146126776256 NOTICE: destroy
13:31:13 T:140146126776256 NOTICE: closing down remote control service
13:31:13 T:140146126776256 NOTICE: unload sections
13:31:13 T:140146126776256 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:31:14 T:140146126776256 NOTICE: destroy
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
13:31:14 T:140146126776256 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
13:31:14 T:140146126776256 NOTICE: closing down remote control service
13:31:14 T:140146126776256 NOTICE: unload sections
13:31:14 T:140146126776256 NOTICE: application stopped...
