When you first add from zip, do you need to add all the modules and plugins etc or do you just add the individual addons for the addon you want?
If you install an add-on from a zip file you have downloaded the process is automatic, there is only install.
If you manually unzip the add-on to the skin folder it should be in a main folder of the add-on, you need to copy all files
AFAIK all add-ons are individual?
Unless you using something like XBMC HUB that has made many XBMC install unusuable.
