Full Version: ERROR: ActiveAE::InitSink - failed to init
Been having issues with sound after upgrading to Ubuntu 14.04.1 and Gotham
The debug log is having issues with the Active Audio Engine full debug log below
xbmc.log
I've been through it but can't see whats going wrong, it appears after awhile to just fail to initialize.
any ideas would be appreciated.
which ubuntu version did you run before the upgrade?
dpkg -l | grep mesa | pastebinit
Disable "Adjust Refreshrate to match video" as a first workaround. Your hdmi driver goes nuts when the refreshrate is changed. Make sure to update to 13.2 prior to further testing.
(2014-08-07, 07:11)wsnipex Wrote: [ -> ]which ubuntu version did you run before the upgrade?
Should i install
libgl1-mesa-dri-lts-trusty
to replace the precise one?
mesa
have since got home and checked the audio settings and pass through device was not enabled. i have now enabled this and will see if the issue returns.
Looks like the settings didnt quite carry over from XBMC 12.3
our Gotham FAQ tells users to redo their audio settings
Hello everybody:
I have a line with exactly the same error in my kodi.log repeated a lot of times:
No other line with other related error. So, has anyone any idea of what is causing this error and how can it be solved?. As far as I see in other forum pastebins ther is a lot of people having it.
Thanks in advance
No Debug Log no issue
