2014-08-07, 14:32
I HOPE this is an XBMC and not a Minix question.... I'm a newbee.
I run a Minix X8-H with LAN access (set up with a fixed IP) to play movies etc. from my various NAS in my home LAN. It works great with everything I throw at it. However ...
I would like so set up all of the XBMC's on my various Windows 7 computers (which also have fixed IPs in the same net) to play from the same, central MINIX database according to the idea described in this video: http://wiki.xbmc.org/index.php?title=MySQL Ii.e. using a single, shared database and NOT the newly built in UPnP feature of XBMC itself. (The latter currently still has too many real down sides to be useable.)
My problem is, that I cannot communicate with the SQL server (or latch up to the database) on the MINIX to either add another network user or to find out which credentials to use from Windows setups. Using "xbmc" as username and password in the advancedsettings.xml on my Windows PCs does NOT work. The Minix XBMC is however fully reachable from all PC's, so it's probably NOT a network problem. Maybe I have a permissions problem??
What am I doing wrong? How can I solve the problem? The results of the YouTube Video sample looked so good!
