2014-08-09, 19:27
Please can you help, 2 problems, suing XBMC;
1. Using XBMC, when I direct download via a Mash up link, it shows me that the download has started, but after a few seconds the info disappears. The file is still downloading, but were can I see a progress bar showing how many per cent has been done. Also, Must I keep the link up, or can I exit to another movie whilst downloading the first one.
2. Some videos (only a few) from my pc, will not play properly when I stream via the xbmc program on the android box. The picture is grainy & pixelated & green ish, and the sound squelches and makes high pitch tones. Is there an issue with certain file types, or perhaps some settings need to be adjusted in xbmc.
Thank you for any help you can give me,
