Full Version: Only old version shows in skin list?
Hi all.
Just updated XBMC after using an old version for ages and I noticed I still had an old version of T, version 5 something, so all the options like Update Library etc were missing..
Anyway, went to update in the skin list and only this old version would show up as available, so I had to download the zip and install it manually to get it working.
Just wondering what I have to do to get XBMC to refresh the list of skins so I can see the latest versions, so I can get updates in the future?
Thanks for any info..
So simple! thank you, had a bunch of updates waiting after doing that, and the new versions show.
