Full Version: Confluence add menu item
With XBMC v12 it was possible to add to the "Home.xml" file an entry to add my playlist to the home menu
                <!--  This section creates a new Menu called "myPlaylists" -->
                <control type="grouplist" id="myPlaylists">
                    <include>HomeSubMenuCommonValues</include>
                    <onleft>myPlaylists</onleft>
                    <onright>myPlaylists</onright>
                    <visible>Container(9000).HasFocus(buttPlaylists)</visible>
                    <include>HomeSubMenuPlaylists</include> <!-- Buttons for the grouplist -->
                </control>
                    <!--  This section creates the custom dropdown sub-menu. -->
                    <!-- Use the name included in the GroupList above. -->
                    <item id="buttPlaylists">  <!-- This is the actual category button -->
                        <label>myPlaylists</label>
                        <!-- <onclick>ActivateWindow(Videos,special://profile/playlists/video oder special://videoplaylists oder Videos,Playlists,return)</onclick> -->
                        <onclick>ActivateWindow(Videos,Playlists,return)</onclick>
                        <icon>-</icon>
                        <thumb>-</thumb>
                        <visible>!Skin.HasSetting(HomeMenuNoWeatherButton)</visible>
                    </item>
then I had to modify the "IncludesHomeMenuItems.xml" file as well
    <!-- Untermenüs für den Playlist Button -->
    <include name="HomeSubMenuPlaylists">
        <control type="image" id="sbmPlaylistsLeft">
            <width>35</width>
            <height>35</height>
            <texture border="0,0,0,3" flipx="true">HomeSubEnd.png</texture>
        </control>
        <control type="button" id="sbmPlaylists1">
            <include>ButtonHomeSubCommonValues</include>
            <label>PC-Videos</label>
            <onclick>ActivateWindow(Videos,special://profile/playlists/video/PC_Win8_Video.xsp,return)</onclick>
            <visible>True</visible>
        </control>
        <control type="button" id="sbmPlaylists2">
            <label>1TB - Animation</label>
            <onclick>ActivateWindow(Videos,special://profile/playlists/video/Extern_1TB.xsp,return)</onclick>
        </control>
        <control type="button" id="sbmPlaylists3">
            <label>2TB - MKVs</label>
            <onclick>ActivateWindow(Videos,special://profile/playlists/video/Extern_2TB.xsp,return)</onclick>
        </control>
        <control type="button" id="sbmLectFiles">
            <label>744</label>
            <onclick>ActivateWindow(Videos,Files,return)</onclick>
        </control>
        <control type="image" id="sbmPlaylistsRight">
            <width>35</width>
            <height>35</height>
            <texture border="0,0,0,3">HomeSubEnd.png</texture>
        </control>
    </include>
With v13 of XBMC it seams completly different Sad
I miss so much my playlist as menuitem Nod
So I hope you can guide me to do this with v13 too.
thX Erich
I managed it.
The files are located unter "Program Files (x86)" and not like supposed in "AppData\Roaming\XBMC".
So can be closed.
GreeT`s Erich
