Full Version: Audio debugging
Hi
For most part I have gotten Kodi to work the way I like it, truly a great program.
However I'm wondering why it constantly sets output channels to "2" even when the input so to speak is multichannel (5.1)? Of course I have it set to 8 channels/24 bit in Midi setup and 5.1 inside Kodi (dosen't make a difference if I use passthrough or not). Computer connected with hdmi to AVR.
If some one have time, plz have a look at my log, specifically these lines:
NOTICE:         m_channels        : FL,FR,UNKNOWN7,UNKNOWN8,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4
http://pastebin.com/DGTW5tcc
Somehow it detect that my AVR is capable of multichannel but lists most of them as unknown and thus outputs only 2 channels?
I'm also curious too what these lines mean (there are a lot of them during a normal length movie:
22:22:45 T:4692414464   DEBUG: CPullupCorrection: pattern lost on diff 40000.000000
22:22:50 T:4692414464   DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
22:24:43 T:4692951040   DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:2402054528.631028, should be:2402064532.780020, error:10004.148992
22:26:00 T:4692414464   DEBUG: CPullupCorrection: pattern lost on diff 40000.000000
Regards
H
I'm not much of an expert when it comes to audio, but 2 channels is the normal setting for multi channel audio. They are digital channels not analog (stereo) channels and so can transmit much more than just right and left audio.
2channel is only normal for SPDIF.
guess one of the audio guys can take a look what is happening
Well for passthrough it should work already as this is up to the avr to decode. For the PCM path (having passthrough off and speaker set to 5.1 in xbmc) it seems that you haven't a correct channel mapping setup in your osx-audio-midi-setup. Verify that each channel in audio-midi-setup is bound to a speakernumber (ensure to confgure the multichannel layout - not only the stereo layout).
Hi and thanks for your support!
Well, the midi setup för hmdi output is 8 channels and 24 bits (can't post a screen dump it seems) and xbmc internally is set to hdmi and 5.1. Dubbel checked!
The 2 questions I have is why the remaning channels come up as unknown in the log and why it seems to select only 2 channels.
In regards to these two questions it dosent matter if I have passthrough on or off, it is still unknown and only 2 channels seems to be selected.
Is there anything I can do over at my end to help you guys?
Regards
H
As i Said they come up as unknown if there is no valid speakerlayout configured in audio midi setup (not only Setting it to 8 Channels but also assign the speakers to those channels)
Post a Screenshot of the audio midi setup speakerlayout screen
