Full Version: Set Time on themes.
hi,
I know there is a setting in aeon mq for the transition time in multi-pictures folders.
the problem is that doesn't work if i select a Main theme with lots of images inside folders.
I would like to delay it, its changing to fast for me.
And by the way.. is there a way to set the pictures in themes go in "order".. nor in "random"?
I rename all the pictures so they have numbers in the beginning so the backgrounds would go in order but there is no option in xbmc..
¿any chance to fix this with some *.xml file?
thanks.
Big GrinBig Grin
