Full Version: Error in build ffmpeg in Helix Kodi and Cmake
First I run Buildffmpeg, and get files, extract ok, but make-mingwlabs is broken now, don´t generate .lib, escape...
I don´t see any info in wiki about how work for get cmake addons, it´s necessary others program for this work, because when run Buildsetup, after pvr done, generate escape and don´t generate more install, have step how procede ?
If I go in tools, buildsteps, win32, and start make-addons bat, I don´t see any progress;
I Try all new today with latest changes in Kodi Helix.
thanks for any info about
Run BuildSetup.bat
Thanks Martijn, I know, dependencies ok (run 2 bat in build dependencies), Run after BuildSetup.bat (see my post, I inform run the bat), this is specific for 2 things, for me don´t compile ffmpeg (I get backup .lib) and pass, but after compile code, copy files, generate pvr addons, when start cmake, exit, I believe have step necessary here, but I don´t have idea next step and how procede for generate install ok. And readme file (next BuildSetup.bat) need care too..
Have you installed cmake?
Nope..I will see now, thanks again.
PS:
Find here
http://www.cmake.org/files/v3.0/cmake-3....32-x86.exe
cmake generate fine now, well done.
One extra for fix: RssFeeds.xml file continue don´t show in home, for see run nightlies in portable mode, file go to wrong place.
