Full Version: Only one channel not working
I have pretty stable environment now, pretty pleased with it. Only have one problem left; Nick Jr. isn't working. Now my son really loves this channel so its really annoying.
See log files: http://pastebin.com/WkB2Kqpt
I rebooted my Xbmc (openelec 4.1.4), tuned to Eurosport 2 HD, this works. Then i hit the channel up button, it should tune into Nick Jr. But it does nothing, no sound, no image. If i look at the TVHeadend backend I see the channel being tuned into and it says it has good reception. After the faulty channel change i switched back to Eurosport 2 HD.
The channel does work on my normal DVB-C set-up box, no problems at all.
Tuning into a channel on the same MUX also works.
OpenElec has the following change log which might be important:
update to ffmpeg-2.3.2
libva-intel-driver: add FD82466 patch
Oh, just tested, if I manually start a recording from the webinterface of TVHeadend I can play the recorded file in XBMC.
Don't know if there is something you can do with it but a recording of 63MB: https://dl.dropboxusercontent.com/u/3926...4-08-17.ts
When i start the TVHeadend stream on my ipad it works, the stream get's played (including sound and video).
Any ideas what could be wrong?
Have you tried rolling back your tvheadend to a slightly older version (like a month older)?
(2014-08-17, 09:51)negge Wrote: [ -> ]Have you tried rolling back your tvheadend to a slightly older version (like a month older)?
No, i haven't, could that be it, even though the same stream works for an Ipad? And doesnt for both the installs on reaspberry pi and intelnuc? I'm willing to try ofcourse, but since i'm using a synology with a package installation, it is pretty hard to roll back the installation (atleast for me it is).
Streaming to an iPad uses HTTP while XBMC uses HTSP.
I have the same issue. https://tvheadend.org/issues/2222
I thought i replied this thread a while back, but the message hasn't come trough..
well, @negge is right, ive tried a 3.4 vesion of tvheadend and that works. So it's not a xbmc problem.
tnx anyways
