Full Version: Helix bug reports
Pages: 1 2 3 4
(2015-03-30, 09:46)telemobb Wrote: [ -> ]Any idea how I can make edits to the /system folder? Whenever I try I get "Read-Only" error?
I just used the file explorer on my Minix to get the file and then used the default text editor to edit the files. Could be a permission issue with your system. I could write to the file without issues on a stock rom, so I am not sure. If you need root access or a custom firmware the freaktab forum is a good start http://freaktab.com/forum/tv-player-supp...tc-devices
When Adding a Timer via the EPG I don't get the options menu and can't record a program.
Live TV -> Guide -> Context Menu on a TV show -> "Add Timer"
I get a dialog for "Record <The TV show you just selected>? [YES] [NO]"
If I hit yes, nothing happens.
In Confluence I get a further dialog with options.
(Using Isengard)
Pages: 1 2 3 4
