Full Version: Because so many errors ??? My image is waging
Because so many errors Huh My image is waging
mbratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 11 duplicate log lines suppressed
Aug 21 23:18:17.059 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 12 duplicate log lines suppressed
Aug 21 23:18:22.033 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 29 duplicate log lines suppressed
Aug 21 23:18:22.034 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 12 duplicate log lines suppressed
Aug 21 23:18:22.034 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 13 duplicate log lines suppressed
Aug 21 23:18:22.176 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error
Aug 21 23:18:32.180 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error
Aug 21 23:18:32.180 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error
Aug 21 23:18:32.180 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error
Aug 21 23:18:33.386 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 19 duplicate log lines suppressed
Aug 21 23:18:33.386 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 10 duplicate log lines suppressed
Aug 21 23:18:33.387 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 9 duplicate log lines suppressed
Aug 21 23:18:33.409 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error
Aug 21 23:18:35.618 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 1 duplicate log lines suppressed
Aug 21 23:18:35.656 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 21 duplicate log lines suppressed
Aug 21 23:18:35.656 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 11 duplicate log lines suppressed
Aug 21 23:18:35.656 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 12 duplicate log lines suppressed
Aug 21 23:18:35.659 parser: transport stream MPEG2VIDEO, DTS discontinuity. DTS = 18507489, last = 18405387
Aug 21 23:18:36.186 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 24 duplicate log lines suppressed
Aug 21 23:18:36.190 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 13 duplicate log lines suppressed
Aug 21 23:18:36.190 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 14 duplicate log lines suppressed
Aug 21 23:18:36.311 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 2 duplicate log lines suppressed
Aug 21 23:18:36.485 parser: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 18501125, last = 18369365
Aug 21 23:18:37.046 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 31 duplicate log lines suppressed
Aug 21 23:18:37.046 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 16 duplicate log lines suppressed
Aug 21 23:18:37.046 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 18 duplicate log lines suppressed
Aug 21 23:18:37.046 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 4 duplicate log lines suppressed
Aug 21 23:18:37.529 parser: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 18520298, last = 18362618
Aug 21 23:18:37.728 parser: transport stream MPEG2VIDEO, DTS discontinuity. DTS = 18705687, last = 18603585
Aug 21 23:18:37.921 parser: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 18630725, last = 18524885
Aug 21 23:18:38.713 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 6 duplicate log lines suppressed
Aug 21 23:18:38.765 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 47 duplicate log lines suppressed
Aug 21 23:18:38.765 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 28 duplicate log lines suppressed
Aug 21 23:18:38.765 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 28 duplicate log lines suppressed
Aug 21 23:18:38.765 parser: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 18636938, last = 18531098
Aug 21 23:18:39.614 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 7 duplicate log lines suppressed
Aug 21 23:18:39.631 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 29 duplicate log lines suppressed
Aug 21 23:18:39.631 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 48 duplicate log lines suppressed
Aug 21 23:18:39.631 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 29 duplicate log lines suppressed
Aug 21 23:18:40.027 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 51 duplicate log lines suppressed
Aug 21 23:18:40.027 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 32 duplicate log lines suppressed
Aug 21 23:18:40.028 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 32 duplicate log lines suppressed
Aug 21 23:18:40.516 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 8 duplicate log lines suppressed
Aug 21 23:18:41.158 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 38 duplicate log lines suppressed
Aug 21 23:18:41.158 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 71 duplicate log lines suppressed
Aug 21 23:18:41.158 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 37 duplicate log lines suppressed
Aug 21 23:18:43.117 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 80 duplicate log lines suppressed
Aug 21 23:18:43.117 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 40 duplicate log lines suppressed
Aug 21 23:18:43.117 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 45 duplicate log lines suppressed
Aug 21 23:18:43.155 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 9 duplicate log lines suppressed
Aug 21 23:18:45.725 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 10 duplicate log lines suppressed
Aug 21 23:18:46.113 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 94 duplicate log lines suppressed
Aug 21 23:18:46.113 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 48 duplicate log lines suppressed
Aug 21 23:18:46.114 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 53 duplicate log lines suppressed
Aug 21 23:18:46.329 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 11 duplicate log lines suppressed
Aug 21 23:18:46.446 parser: transport stream MPEG2VIDEO, DTS discontinuity. DTS = 19438419, last = 19111092
Aug 21 23:18:46.549 parser: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 19408325, last = 19043285
Aug 21 23:18:46.549 parser: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 19414538, last = 19049498
Aug 21 23:18:48.118 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 113 duplicate log lines suppressed
Aug 21 23:18:48.170 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 12 duplicate log lines suppressed
Aug 21 23:18:48.174 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 63 duplicate log lines suppressed
Aug 21 23:18:48.175 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 67 duplicate log lines suppressed
Aug 21 23:18:53.209 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 115 duplicate log lines suppressed
Aug 21 23:18:53.275 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: CA #2656: Continuity counter error, 13 duplicate log lines suppressed
Aug 21 23:18:53.303 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 64 duplicate log lines suppressed
Aug 21 23:18:53.303 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 68 duplicate log lines suppressed
Aug 21 23:18:54.138 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO #2653: Continuity counter error, 118 duplicate log lines suppressed
Aug 21 23:18:54.138 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #32: Continuity counter error, 66 duplicate log lines suppressed
Aug 21 23:18:54.138 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2AUDIO #2651: Continuity counter error, 70 duplicate log lines suppressed
Aug 21 23:18:55.109 TS: Montage Technology DS3000/Embratel: 12,120,000 kHz Vertical (Default (Port 0, Universal LNB))/AXN: MPEG2VIDEO @ #2653: Continuity counter error, 121 duplicate log lines suppressed
Bad signal ? Adjust your antenna
In argus not have this problem! And my antenna is in the best position in own unit shows 70% signal quality.
Could be a few things...
1. IRQ conflict if using PCI/PCI-E, or could dislike running in a too fast PCI-E slot
Solution, change to MSI IRQs for the device, and/or set bios to 1x for PCI-E port card is using.
2. Make sure full mux reception is off.
3. Check cabling
4. Driver issue
5. Plug in power connector to card if appropriate.
....Likely bad cabling, or interference, none of the above will always give/not give bad signal quality/SNR
As a note though, low "signal quality" means that the electrical signal being received from the dish/aerial is weak, this isn't strictly related to bad reception, you can have a strong signal quality and still crap reception due to low SNR. This would point to bad cabling or power not plugged into card, likely the first as most cards are fine without their power cable plugged in.
Sorry for the vague info and if you already aware of all this.
How can the same plate, has different signal strength? I'm using a tvii s480, which works perfectly with the argus !! However the tvheadend IS MUCH MORE COMPLETE. I need help !! Do not want to leave the tvheadend
I made some changes improved a little bit ..... well .. guess can further improve !!
  What I did:
I disabled the following options:
Idle scanning
Monitor signal quality
Full reception mux = off
I'm still having problems .... I went back to 17%
