Full Version: ClearArt & ClearLogos
I've been spending a bit of time on my 13.2 install downloading ClearArt and ClearLogos for my TV shows.
I've been using the options provided in the skin under 'Extras' when looking at the TV show information, and although they're being downloaded correctly, I can't actually find a view that uses them!
I note that in Movies, it shows a logo (not sure if it's ClearLogo or ClearArt) in the top left hand corner.
Am I going nuts?
check if you've enabled both options in skin settings:
  • TV Shows - Enable clearart
  • TV Shows - Enable logos
logos will be show at the top-left of the screen in the following views:
  • fanart
  • cover flow
  • item
  • slide
clearart is only used on the fullscreen video window during playback:
- on the seekbar (press 'space' on keyboard)
- on the video osd (press 'm' on keyboard)
- on the video info dialog (press 'i' on keyboard)
