Full Version: XBMC Mysql update
Hi All,
I have a windows server 2012 r2 acting as my storage of movies tv series and so on.
Now I installed MySQL and connected all my XBMC's to it and it works fine but..
I wounder if there is a way to update the library with out starting a XBMC client, I want to update the library for example 4 times per day or something so it is updated when I turn on a XBMC client.
Is there a way to do this?
Best regards
Fat
That would be an interesting idea but why?...
You may find that it causes more damage then its worth.
I have gone the otherway and taken updating newly added files away from XBMC in that I use the Media center Master to handle all the TVshow and Movie data updates ... + artwork..
Then get XBMC to scan for the new local NFO data..
As a note I use path substitutes for all the thumbs and artwork as well..
At this stage I am feeling that I have my TV and movie db sorted to include everything I have..
Using the XBMC scan and internal engine to reach out to the net for the artwork and NFO info just gave me to many errors and lost shows..movies and every scan it did..
Now... I can check against the numbers that media master provides and cross references with my NAS.
I am almost settled with this way of doing it but will keep an eye on this thread.
