Full Version: Disable specific ir sensors
Am setting up XBMC 13.2 in Linux Mint 17, x64, fresh install. Would like to not use Lirc.
My issue is that I have 2x USB tuners, which are installed, and configured/working as tuners, but am now endeavouring to setup the remote.
I have another 'standalone' remote, which I would like to use. Unfortunately, this one is not being detected properly by the kernel, as one of the tuner sensors seems to be overriding it. Details:
LSUSB:
john@MediaStore ~ $ lsusb
Bus 002 Device 003: ID 1784:0008 TopSeed Technology Corp. eHome Infrared Transceiver  ## the MCE remote
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 003: ID 0413:6f12 Leadtek Research, Inc.
Bus 003 Device 002: ID 0413:6f12 Leadtek Research, Inc.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 006 Device 003: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T   ## One of the tuners
Bus 006 Device 002: ID 05d8:810f Ultima Electronics Corp.                                   ## Other tuner?
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
~ $ ir-keytable
Found /sys/class/rc/rc0/ (/dev/input/event10) with:
    Driver dvb_usb_rtl28xxu, table rc-empty
    Supported protocols: NEC RC-5 RC-6 JVC SONY SANYO LIRC RC-5-SZ other
    Enabled protocols: NEC RC-5 RC-6 JVC SONY SANYO LIRC RC-5-SZ other
    Name: Realtek RTL2832U reference desig
    bus: 3, vendor/product: 0bda:2838, version: 0x0100
    Repeat delay = 500 ms, repeat period = 125 ms
Found /sys/class/rc/rc1/ (/dev/input/event12) with:
    Driver dib0700, table rc-dib0700-rc5
    Enabled protocols: RC-5
    Extra capabilities: <access denied>
Found /sys/class/rc/rc2/ (/dev/input/event13) with:
    Driver mceusb, table rc-rc6-mce
Think I need to disable the IR on event10 + event12, but obviously not disable the driver, so believe I then can't blacklist the driver..
Hints on how to go about this would be great
Set static names for the devices via a udev rule, eg:
/etc/udev/rules.d/10-persistent-ir.rules
KERNEL=="event*", ATTRS{idVendor}=="0471", ATTRS{idProduct}=="2093", SYMLINK+="input/phillips-ir"
Then disable all input on that device with ir-keytable:
sudo /usr/bin/ir-keytable -c -d /dev/input/phillips-ir
This worked for some years in Libreelec and Coreelec.
But now, the command
gives the error
/usr/bin/ir-keytable: invalid option -- 'd'
Using LE 19.0 Beta 2 on a Allwinner H3 TV-Box
https://forum.libreelec.tv/thread/17565-.../?pageNo=1
Das nobody else has that problem?
Does...
