I have a problem with xbmc. When i open XBMC it keeps crashing and closes by it self and a message pops up sayng xbmc quits unexpectedly. If anyone can help me i will appreciate it very much.
Paste the crash report to
pastebin and post a link here. If you can get a
Debug log (wiki) you could do the same with that.
The XBMC_IPTV_Simple plugin is crashing for you. Go to the
userdata (wiki) folder and find
guisettings.xml (wiki) - you can disable livetv there for preventing it to get loaded (or remove guisettings.xml - in that case you need to reconfigure your settings).
There is another bad python addon in your userdata folder somewhere. Post a
debug log (wiki) we might see which one it is...
